Question about Dishwashers
IGNIS ADL 347 dishwasher - No power or display lights but there is mains supply to m/c. M/C stopped in mid-cycle, water left in cabinet.
4 Suggested Answers
SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Posted on Jul 16, 2008
ginko
  • 19396 Answers
SOURCE: IGNIS ADL 347 DISHWASHER I interupted
Hi.
The Ignis dishwasher does not need reset code. It will normally restart working after tripping the circuit breaker.If the machine is beeping, that means that the dishwasher is in fault mode because some fault condition is detected. Among conditions that can cause the issue, residual water inside the machine, clogged drain, arms jammed.
Try disconnecting circuit breaker and drying water from the inside, also remove the drain well and clean it. Eventually carefully pour some hot water intor the drain well, inside the machine tub.
Connect back circuit breaker and try restarting the machine.
Here a forum on similar problems.
Posted on Sep 11, 2010
caroldon
  • 17129 Answers
SOURCE: my ignis adl 347 dishwasher
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. The drain pump can be clogged and refuse to work as it hums. If so remove and clean the drain pump, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Thank You for using fixya
Posted on Sep 21, 2011
Complete power failure mid cycle. No lights or action. Water left in the bottom. please help! whirlpool adp659s many thanks
remove drain hose and see if its blocked at the main drain where it was connected this happened to mine after running CLR thru it
Oct 19, 2013 | Whirlpool Dishwashers
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
Not working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 17, 2013 | Washing Machines
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
My ignis adl 347 dishwasher will not empty its self i put it on a cycle it hums for a while then it starts bleeping continually and light flashes were you turn it off
Cleaning a pump:
Sep 21, 2011 | Dishwashers
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
My Ignis dishwasher ADL 348 is not dissolving the dishwasher tablet properly leaving the crockery still dirty. It is also making a really strange noise during operation. I have cleaned the filters and the...
My adl 348 is 3years old. Made strange noise and didnt really wash now it doesnt appear to be washing. What would it be and is it easy fixed?
Feb 13, 2010 | Dishwashers
Ariston L63 dishwasher stopped mid cycle with water in base.
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Ignis dishwasher model no. adl 347
Jun 14, 2006 | AEG 24 in. Favorit 40310 Free-standing...
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
Owen Barnes
