Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Water spitting at indoor unit - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
  • 146 Answers
Pull the filters and clean them see if you can see any ice on the coil in side. blow in to drain line out side to clear the line.
Posted on Jun 05, 2010
    Sergeant:
  • 215 Answers
Check the drain line that goes to the outside to make sure it is not clogged.
Posted on Jun 20, 2010
Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Oct 03, 2014 | Heating & Cooling
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
I have an LG Neo Plasma air conditioning unit in the living room and the Inverter in the bedroom. I understand these are set up to work together, however, the bedroom unit starts to freeze up (ice)...
I assume its the outside unit of the bedroom that freezes up ?? If the outdoor temperature is below 5 degrees celcuis, its likely to freeze up on the outdoor coil ( On heating mode), there is a defrost function which defrosts the machine automatically. If the indoor unit starts to freeze up ( on cooling mode), I would suggest that there is a shortage of refrigerant gas. Especially if the indoor unit starts to "spit" water out when it is running. There may be a gas leak due to a pipe failure or loose flared fitting. These must be rectified before recharging with gas.
Aug 04, 2011 | Heating & Cooling
It's spitting out water...only 2 yrs old
What type of system is it? What application (ie) window unit, split system?
Jun 29, 2011 | Heating & Cooling
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
On cool will work for a short time. then will stop regardless of room temperature. If stopped for a short while then restarted will begin to spit water or ice.
Unit stopped by coil sensor when ice formed.
Problem due to weak capacitor of indoor fan motor/short of gas/coil & air filter dust blocked.
Replace fan capacitor/if short of gas, tap up some gas/clean coil and air filter.
Hope, it's helpful.
Feb 26, 2011 | Mitsubishi Heating & Cooling
Spits out water from the indoor unit
indoor coil icing up .gas leak the water is from the dripping coil . or you have left unit on for to long on a low setting
Nov 10, 2010 | Cfm Daikin R410a Split System Air...
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
334 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
