Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
My baracuda sucks up water but will not move and clean the bottom of the pool.... he is static all the timei it is an alpha 3.I charge the tubes from the water outlet to get rid of any air in them. Ialso backwash the filter and clean the prefilter baskets. the pressure guage is at 5.
  • 366 Answers
SOURCE: My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Posted on Apr 08, 2010
  • 366 Answers
SOURCE: Our zodiac works for a
check in internal diaphragm for deformities or debris. un-thread the nut at the top of the unit and push the white pipe downward, when you pull it out of the bottom of the unit, check the condition of the rubber diaphragm. should only have a narrow uniform opening. if its wide open or deformed, it may be causing you some problems.
Posted on Aug 17, 2011
PartsCenter
  • 125 Answers
SOURCE: Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Posted on Feb 26, 2009
SOURCE: baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Posted on May 03, 2009
  • 106 Answers
SOURCE: My Baracuda pool cleaner doesn't work at all
While the cleaner is in the water, see if there is suction on the bottom of it. If not than you probably have a bad hose.(Broken) If there is a lot of suction then the diaphragm probably is either worn out or has a rip or tear in it.
Posted on Feb 24, 2010
Our baracuda is sucking but not moving. how do we fix it?
Use your flow gauge to check for proper water flow. It might need to be adjusted. This is usually the issue when this problem arises with this pool cleaner. Check the diaphragm for blockage, damage, or ware. Also, make sure that your hose weight is 29 inches from your cleaner.
Feb 19, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My Baracuda is dead in the water, water getting sucked in but it won't move? What could be the problem
There are a couple things that you can check if your pool cleaners not moving. First and foremost, use your Pulse Point feature to make sure that you are receiving proper water flow. If you water flow is too low, it will cause the cleaner not to move. Similarly, make sure that your filter and pump are clear of debris (which can also reduce flow). Make sure that there is no excessive wear and tear or damage to the diaphragm of the cleaner. Replace it if necessary. Finally, check for leaks in your hose by lifting each section above water one at a time.
Feb 08, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda alpha 3 has suction but will not move makes a humming noise.
Their is probally a small hole or tear in your diaprham and will need replacement. If you take it to a pool store they will probally do this for you just for the price of the part.
Jul 31, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Feb 24, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda is pulsating and moving but surfaces
The control should be below the water, and if you cut the suction down that should help with the cleaner.
Dec 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda G4 won't clean whole pool. goes to a corner and stays
Apr 25, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
156 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
