Question about Intel PRO/Wireless 5000 LAN Access Point 802.11a
NOT ABLE TO LOGIN WIITH DEFAULT USER AND PASSWORD
    Problem Solver:
  • 6 Answers
If there is a reset button then reset it and then try with default user name and password.
Posted on Jun 21, 2010
Login and password
The default login and password should be in your user manual. If you cannot find the manual, check the MFG website or Google your brand and default login. If you cannot access because of your own password and login, reset the router (manual or website should walk you through this) at which point it should reset login and password to default.
Nov 13, 2013 | Computers & Internet
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Nov 16, 2012 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
Need user and password of canon ir3170
here's the original disk http://www.precisionroller.com/manuals-for-canon-imagerunner-c3170u/products.html. Try these Default system password: user:7654321 , psw:7654321 Default technician password. 11111111 Control panel password: user: Administrator , psw: password
Oct 30, 2012 | Canon ImageRUNNER 3570 Copier/Printer
Don't understand how to set password. please help
Plug the router into the power socket and configure you own machine to obtain IP address automatically. Load up Internet explorer and type in http:/192168.xxx.xxx which is the local address of your router. You should then get a password screen. Enter default user name and password and it will take you to the configuration screen. The full IP address and user name and password are dependant on which model you have. See list below From there you need to read the instructions very carefully and match it with the information provided by your ISP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
? Q: What is the default IP address, username, and password for routers? ? A
ZSR0104
192.168.8.1
Administrator password: admin
ZSR0104M
192.168.1.1
Login password: No Password
ZSR0104B
192.168.1.1
User Name: admin
Password: 0000
ZSR0104AS-01
192.168.8.1
Administrator password: No password
ZSR0104E
192.168.2.1
ZSR0104CP (Grey color)
192.168.1.1
User Name: admin
Password: admin
ZSR0104CP-05 (Blue color)
192.168.10.1
User Name: guest
Password: guest
ZSR0104WE-01
192.168.2.1
ZSR0104WE-04
192.168.2.1
User Name: admin
Password: 1234
ZSR0104WE-05
192.168.1.254
User Name: admin
Password: 1234
ZSR1104WE
192.168.2.1
User Name: Empty
Password: Empty
ZSR0104DE
192.168.2.1
ZSR0104FS
192.168.1.1
User Name: admin
Password: admin
ZSR0104UP
192.168.1.1
User Name: admin
Password: 0000
Dec 22, 2010 | Zonet Computers & Internet
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
Jul 02, 2010 | NetGear WNR2000 Wireless Router
How can we open the router configuration without password.......& usernane
Dear Friend,
If you don't have change your password from factory defaults then look into manual for user name and password...
If you have change your password then, Sorry you have to reset your router. this will delete all your configuration but will set your login id and password to factory defaults... ( there is no other way)
Please rate the answer
Jun 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
I don't remember how to login to my linksys configuration
Hello
I am not sure the IP you put in the message is the right one. Assuming that you are still using the default settings, the IP is 192.168.1.1
open internet explorer or your default browser and type: http://192.168.1.1
and you shoulfd see the login page and if you forget the default login try
user: admin
password: {blank} nothing
or
user: {blank}
password: admin
Apr 13, 2009 | Linksys Wireless-G WRT54G Router
What is the default user name and password to login the Prestige via the browser?
To restrict only the adminstrator can configure the router, there is a login procedure prompted for asking User Name and Password. The default User Name is 'admin' and the default password is the default SMT password, '1234'.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Intel PRO/Wireless 5000 LAN Access Point 802.11a Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
