Question about AOC SoundMax 2.0 Channel Multimedia Speaker System SPK-HY-202 Computer Speakers
The SoundMAX has been uninstalled on my computer. It runs on Windows XP. Do I have to take it back to where I got it to reinstall SoundMAX or can I reinstall it myself from a website?
    Novelist:
    Champion:
  • 226 Answers
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem.
Hope this helps,
www.PuterCare.com
Posted on Jul 04, 2010
Need to reinstall soundmax.. how do I get it?
Download the version of 5.12 soundmax software from the below link http://www.soundmax.com.tw/productlist.asp?action=hot
I hope it will work
Mar 14, 2012 | Computers & Internet
I have asus p5pe-vm motherboard system which i bought 5 years back with windows xp installed, after that a year back i installed windows 7 and i cudnt hear any sound from my system... as well every time i...
http://directx.en.softonic.com/
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 16, 2011 | ASUS P5PE-VM Motherboard
Xp sound driver
did you reinstall your XP operating system recently? Or did it work before? You can take a look into the device manager ( "Windows" + "R" key and in the command line type the "devmgmt.msc") if there is any driver problem.
If yes, try reinstalling the driver. You can find it for example here:
http://download.cnet.com/SoundMAX-Integrated-Digital-HD-Audio/3000-2110_4-146407.html
If you want to find yout if your Sound is working at all and your hardware is ok, then download an Linux live cd, burn the iso on a blank disc an boot it. If you can hear any sounds at start, then it is most probably your Windows settings.
Jan 13, 2011 | Intel SoundMAX Integrated Digital HD Audio
ASUS P5B-E: No Sound after reinstalling XP SP3
THERE IS A SET OF NUMBERS ON THE MOTHERBOARD WHICH ALSO INCLUDES ASUS P5B-E IF YOU GO ON GOOGLE AND ENTER THE MOTHERBOARD NUMBERS YOU SHOULD BE ABLE TO GET THE CORRECT COMPANY & DRIVERS FOR THAT BOARD... GOOD LUCK
Feb 26, 2010 | ASUS P5B-E Motherboard
I am using asus k8v-mx mother board, and im just finished reformmating my system using windows 7. The only problem i had is that my audio driver cannot be installed due to incompatibility results. Can...
1. first download this file:
audio.zip - Audio Driver for Win 7
2. right click on "Computer" and select properties. Open Device Manager.
3. Uninstall Soundmax.
4. Open that zip from step 1 and extract to a new folder on the desktop.
5. Run Setup.exe and complete.
6. Restart.
7. Once you are back you're sound icon will be missing from the tray and windows will reinstall the soundmax drivers.
Nov 28, 2009 | ASUS K8V-MX Motherboard
PLACA M925LR ESTE TEMA ES ANTIGUO PERO TENGO UNA PREGUNTA. LOS JUMPERS J2A/B/C/D Y J3/A/B/C/D DONDE ESTAN, LOS VENDEN? HAY QUE CERRARLOS PAR A PAR, POR AHI ALGUIEN DICE QUE ESTAN EN LA PLACA, ¿DONDE?
6. Restart.
Nov 27, 2009 | PC Chips (M925G) Motherboard
No sound on my Windows XP desktop
Sound may be muted in the control panel
click the icon in the tray to bring up the
Sound control panel and check for a mute
Apr 23, 2008 | Microsoft Windows XP Professional for PC
Soundmax
I don't know if you manually erase those drivers, but I recommend you reinstall the drivers with the setup option, then uninstall them, again reinstall them ans see if work, or depending the OS if is Xp or Vista, ?
Nov 06, 2007 | Audio Players & Recorders
Dell speakers
Chances are that when you deleted Soundmax, you deleted the drivers as well. I am going to assume that you 'deleted' the "Soundmax" entry from your Add/Remove Programs console or chose "Uninstall" from the Soundmax folder in your start menu.
The problem is not your speakers. The problem is the audio hardware. I'm willing to bet that you don't have any drivers installed for your Soundmax audio hardware.
More often than not, when you uninstall the software for your audio hardware, it also removes the drivers for the audio hardware.
I would try re-downloading the drivers for your Soundmax hardware and reinstall them.
Soundmax Drivers:
http://www.techspot.com/drivers/driver/file/information/3312/
I am also aware that this Soundmax chip was licensed to a different company by Realtek. (They designed the chip.) You can also try the Realtek AC'97 audio chip drivers. There may be a few differences in the way the software works, though. Here you go:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#AC
I myself would recommend the Realtek Drivers. However, I also have an experience with this particular chipset where I installed the drivers in Windows XP Service Pack 1 or below and they worked just fine. But if I installed the drivers in Windows XP Service Pack 2, the system just reboots itself over and over again unless I use Safe Mode and uninstall the drivers.
Instead of fighting with that issue, however... I just put in a different soundcard and deactivated the onboard audio hardware in the motherboard's BIOS.
Just a heads up on that...
Good luck with this. Let us know what happens if you need more help.
Cyryl
Nov 04, 2007 | Audio Players & Recorders
129 people viewed this question
Top AOC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AOC Audio Player and Recorder Expert? Answer questions, earn points and help others
