Question about Tappan TGF657 Gas Kitchen Range
A tenant took off the knobs off the part of the stove that control the burners. we can only find one. can not find model number or part number. it is a tappan, 30 inch, electric stove, white with black front knobs. can you help? where would model number be?
    President:
  • 3,085 Answers
Usually on the frame when you remove the bottom drawer
Posted on Jun 05, 2010
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Sparks came out knob of electric stove
What is the model number of your unit?
Nov 24, 2012 | Kitchen Ranges
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Right front electric stove is stuck on high without shutting off, regardless if knob is switched to off. Needed to unplug the stove completely from electricity.
it depends on the model and manufacturer of your stove .. some have solid state relays that could be shorted (usually computer controlled stove) or a conventional relay (for cycling) that may have a stuck contact .. if its a conventiional stove with spiral cooking surface (not smoothtop) .. then you can make sure the burner is not hot and the stove is unplugged .. then you can simply lift and pull the burner out of its socket .. that will get you working temporarily on the other burners until ;you can fix the problem .. that burner could have an internal short to ground .. easy to check with an ohm meter or by substitution of one of the other burners .. if another burner does the same thing then suspect the relay or control switch ... if the substitute burner works properly then replace the defective one ..
Sep 28, 2009 | Kitchen Ranges
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Tappan TGF657 Gas Kitchen Range Logo
134 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
