Question about Refrigerators
Looking for Oster stainless Steel water dispenser model 0279 parts. Particularly the hot water valve. The red one on the left. Do you know where I can buy this item? Thank you.
  • 4 more comments
  • Anonymous May 12, 2008
    Oster hot water, red one. It's a red press-down handle easy to break; I would not recommend anyone buying this product, model Oster 0279; So far I can not find any replacement part;
  • Anonymous Jun 24, 2008
    I have the same problem, the red tap is broken. seem so far this is a poorly made product.
  • Anonymous Sep 02, 2008
    guess what? I have the same problem. I'm glad I saw these postings or I would have spent all day trying to get a replacement part. Thanks
  • weihmail Dec 31, 2008
    I have the same problem with the red hot water valve. Thanks for sharing!
    Seems this is their main defect.
  • Anonymous Apr 24, 2009
    I also have the same problem with the oster water dispenser unit, where the hot water just drips and drips even if i turn it off. I called oster and they really did not want to help me at all. they told me to just clean the machine. I cannot resolve the problem, so i recommend not to buy these water dispensing machine from oster. M.weston
  • Anonymous May 25, 2009
    I have the same problem!!! The safety lock broke and then the RED handle broke, so I took it apart to get to the spigot handles (cutting the knuckle off of my index finger on the sharp housing trying to get the top off!!!) and when I pulled the spigot assembly apart the rubber interliner got a small tear in it which caused a continuous drip that drained the last of the water all over the kitchen floor! Thank god I did not replace the bottle or the mess would hve been 5 gallons worse!!!
    Thanks for the number for customer service!!! We can't find our original paperwork!
This part is not available online. If you call customer service at 1-877-383-6399 they will send you a new part with instructions on how to install it for $13.00 including shipping.
Posted on Sep 17, 2008
  • House_repair Aug 03, 2011
    August 2011 - very accurate info, now total cost is $14.35 but still cost less than replacing cooler.
Fast forward to 2011, and the problem with the bad design of the hot water valve remains. I have to refrain from buying this brand in the future.
Posted on Apr 05, 2011
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
GSS22SGR Stainless Steel Side by Side Refrigerator. Poor ice making and when the water dispenser is pushed, the water goes out to the floor through the water valve on the back of the fridge. What could be...
The problem sounds as if either the tubing to the water valve in the back is cracked or disconnected from the valve so the water is leaking onto the floor instead of into the i/m or door dispenser.
GENE
Oct 06, 2011 | GE GSS22SGR Stainless Steel Side by Side...
Doe s anyone knows how to charge R12 Ge model
Keep looking for the access on the high and low side. Some of the valves look a little different but you should be able to find where to hook the gauges. R12, R22, and 134a all charge the same way and use the gauges and hoses. just make sure you have pressure temperature chart.
I hope this helps
Apr 20, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Water dispenser not working on door
That should not be a hard to fix problem . On rear of your refrigerator you have a set of two control valves. Part number WR57X10032 and it has two sides one for ice maker and the other for water dispenser. You can unplug the water dispenser plug and test for 120 volts while someone presses dispense water. If you get voltage and valve does not open just replace complete valve. Sea Breeze
Jan 23, 2010 | GE Profile Arctica Stainless Steel Top...
Water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | Refrigerators
Ice maker does not make ice.
The water dispenser and the ice maker use a different side for each one. The water control valve is most likely the problem. To test the ice maker fill with tap water and let freeze. If the ice dumps then the water valve is the problem. If you need part numbers I will need your model number. Thank you Sea Breeze
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE side by side stainless steel refrig. the water will not dispense. How can I fix it?
Is there water to the water valve in the rear of the fridge? If yes, replace the water filter if older than 6 months or if you're on a well. You may need an inline water filter behind your fridge in addition to the one in the fridge to protect the water valve. If no, turn on the water. If you're making ice but no water dispense and you have a new water filter. Replace the water valve.
Dec 10, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
1,199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
