Question about Datamax I-4308 Thermal Label Printer
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped and I have to wait a lot to start again. Also another problem: during printing device stops suddenly,no error on display ,after turn off from supply and turn on starts again after we cancel nr of labels . It happens 3 times/day without any warning
  • 857 Answers
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Posted on Jun 05, 2010
Reversing Labels before Printing
It's called "Present Distance" and it can be set to "0" in the printer's control panel. Look under Print Control.
Jan 21, 2014 | Datamax Office Equipment & Supplies
Toshiba continuous printing extra label printing
If connected to a pc use the pc to tell it to cancel all printing.
Oct 18, 2013 | Datamax I-4308 DT/TT Thermal Label Printer
I am using Bartender software and a I4208 printer. It won't print on the first 1/10th inch of a 1inch x 4inch label. It also won't present after printing. Any help would be great. This printer is set up as...
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4308 Thermal Label Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
We have just gone live on sage 1000 and are trying to print labels designed in sage paperless to send to our Datamax m-4206. Labels print but we cannot get the information to line up on the labels. Is...
This can be caused by either the software, or the printer's electronic or mechanical settings. Software will usually override the printer settings for print speed, temperature, label dimensions, etc. In order to fully diagnose, I would need to know if the print is too high, too low, too far left or right, or skipping a label, etc.
Nov 08, 2010 | Datamax M-Class M-4206 Thermal Label...
Not printing
If you send a format and the label advances but does not print, then it is possible that the darkness setting is not high enough for the label/ribbon combination. Depending on what software / printer driver you are using, many times the darkness setting in the software or driver will override what is in the printer. This makes it possible to have the test print work just fine but no printing when a label format is sent the printer.
If you are sending a format and nothing at all happens at the printer, then that is a communication issue. How are you connecting the PC to the printer ?
Apr 19, 2010 | Datamax I-4308 Thermal Label Printer
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Printer stays in a SND mode
Have you check the firmware issue?
Nov 05, 2008 | Datamax I-4308 Thermal Label Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Datamax I-4308 Thermal Label Printer Logo
630 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
