Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My tv stopped working. it shut off and the power light blinks green for a little bit then blinks red. Before it shut off it sounded like glass cracking or the sound of a light bulb breaking.
  • 973 Answers
It sounds like your Lamp inside your TV burnt out, You will need to replace it, you can order one from Sony and install it yourself. Here is the link
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040980&tab=featuresTab
Posted on Jun 05, 2010
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
