Question about Hayward H-Series 200k BTU Millivolt Heater - Natural Gas
My hayward h series minivolt heater works for about 1hour then shuts down and when started again shuts down after 1to 2 minutes
  • 33 Answers
This is a fault in the control system...prob the high limit switch or pressure valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
When the burners ignite, within one minute it starts making a loud banging noise and then the HS code comes on and it shuts down. the noise continues for about 15 to 30 seconds after the burners shut...
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Jul 18, 2011 | Hayward H-series Electronic Gas Pool...
Hayward H 300 series pool heater for an inground pool. Pilot light is lit. Filter is clean. If I jump the terminals the heater will go on. If not the heater will not start.
I have an H300 Millivolt Hayward heater. It will start and run for about 1 minute then shuts off along with the pilot going out. I've tried cleaning all the terminals and running all new wiring but same result. I've also jumped out the TH to TH terminals leaving the jumper in place and it still shuts down after 1 minute. Any idea what that could be ?
Apr 24, 2011 | Hayward H-series Electronic Gas Pool...
Lo error showing and it kicks off about every 6 minutes
Thank you for posting your question here on Fixya.com.
A 'LO' error code for a Hayward heater is a limit string open error. If the limit string opens the heater shuts down and goes into lockout. Automatic restart is 2 minutes after the error condition is corrected and the limit string closes.
The limit string is a series of switches designed to turn off the heater if air or water temperatures exceed a safe operating limit.
The problem may be faulty a switch(es) but is far more likely to be a system condition the switches are reacting too that needs to be corrected. Low flow of combustion air due to obstructions around the heater or the vent; low flow of water through the heater allowing too high a water temp; Poor venting or sooted-over heat exchanger causing flame rollout. These are all conditions that should be eliminated if they exist.
If you are not familiar with these switches or the conditions described you may want to consider calling in a professional. Hayward can refer you to someone in your area who is. Call Hayward at 908-351-5400 or try the website locator found here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Mar 23, 2011 | Hayward H Series Pool & Spa Heater 400k...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Heater fires but only runs 2 minutes then shuts off is a model abg100 swim pro by hayward
the pump is not circulating, so the high limit is shutting it off. You need to check out your circulating pump
Sep 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
My Hayward pool 350000 heater will light and stay lit and heat the pool for a while, but will just shut off including the pilot light. When I re-light it it works for a while again and then shuts off...
Sounds like the pilot assy needs to be replaced. It has 2 functions one is to light the main burner but also to let the system know that the burner is lit. If it thinks the burners are not lit it turns the gas off
Jun 23, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H-Series 200k BTU Millivolt Heater - Natural Gas Logo
159 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
