Question about Garden
How to fit pull cord mcculloch m3540 - Garden
  • 177 Answers
Find he manual online or your own
Posted on Jun 07, 2010
How do I check my mcculloch h2000 for spark?
Hi Tim:
I would remove the spark plug, connect it to the lead, hold it against the engine, turn the ignition switch to ON, and pull the start cord. You should get a hot blue spark.
Cheers
Jan 04, 2016 | McCulloch Garden
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Why does the cord keep breaking
Barbara:
You should probably go to a lawnmower repair shop and buy a nylon pull cord. The cord must be able to withstand fuel and oil. If any old cord is used, it will break eventually.
Jul 01, 2014 | McCulloch Garden
Need to know how to test coil, and need setting of coil to the flywheel. McCulloch 3200.
There are two ways you can check for spark.one way is to take the plug out and hook the plug wire to it and place it on the top of the head and pull the cord and see if plug fires.the other way is to use a spark tester.hook the tester up to the plug and plug wire then pull cord and see if light in tester lights up if it doe,s you have spark.the setting for the coil to flywheel is .010.
Dec 24, 2010 | McCulloch Garden
When trying to pull start my Mcculloch chainsaw 338, its all jerky. ok last season. Help please.
Take the spark plug out and pull the cord to see if it stuck.
Drain all gas and get a new mix.Put back the sp and start.
If thr cord was unable to pull,thr pisto and crankshaft must be service.
Oct 26, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to replace chain on McCulloch chain saw? How do you get the brake over the drive wheel to reaffix the outer cover and brake release?
The chain brake is engaged. support the cover firmly (as it will require a lot of pressure to pull the handle) and pull back towards the operator. When it is re-set, it will then fit properly to be assembled to the saw.
Nov 28, 2009 | McCulloch Garden
How do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
Fr2.0 14'' McCulloch chainsaw has no spark when holding spark plug wire while pulling the cord.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If you really sure there is no spark turn on the ignition, put your pinky finger in place of the plug, and give a short pull. If you didn't get shocked the coil, switch, or wiring is bad.
You can find an IPL for your saw here:
McCulloch International
http://www.mcculloch.biz/
The model you provided does not cross. A number on your saw will match something. Your coil part number can be found there. HTH
Lou
Oct 15, 2009 | McCulloch Garden
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
