Question about Chatterbox GMRS-X1 (15 Channels) 2-Way Radio
My chatter box will not transmitt more than 1/2 of a mile
  • 12,061 Answers
Well from my research, this unit outputs about 2 Watts. Now that's NOT a lot of transmission power, really. However I would still expect it to go more than 1/2 mile. The most important thing with any 2 way radio, is the Antenna. it needs to be mounted clear of anything at BOTH ends. Having ensured that the Power Must be 100% a bad battery will equal low output and poor sensitivity. Now if that's all OK, then the only other thing it can be is interference this can cause a lose of signal, as signals heterodyne with each other. As well check ALL wirings and connections for good contacts.Also if possible, test another unit out and see just what range you should expect?
http://www.chatterboxusa.com/images/downloads/manual-X1BT.pdf
Manual above.
Posted on Jun 05, 2010
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Tip
Using a video transmitter to extend your cable network to another TV in the...
When I first purchased a cable plan I only had one TV in my house and it seemed like a waste to get multiple cable boxes for TV that I had not yet purchased. When the prices came down on TVs I decided that it was time to get a set to go in my bedroom upstairs but I didn't have a cable box to connect to the set.
I could have gone out and spent a $100+ on a new bulky cable box that is not really all that pretty or I could get a video transmitter that will extend my signal to the upstairs TV set for around $50. Even though it takes a little bit of set up the results are great, I can even use the one remote on both television sets.
To set up your video transmitter first you have to take the transmitter and receivers out of the box and make sure that they are both set to the same channel. This will ensure that they will read each other. Then you take the cables that came with the transmitters and connect them to the back of the cable box, matching up the yellow, red and white cables to each other. Position the transmitter box so that it is lined up with the signal transmitter of the cable box.
Then you want to go upstairs to the second TV and connect the receiver to the back of the television set the same way that you connected the transmitter to the cable box. Take the remote from the set downstairs and it should have extended the connection of the cable box to both TV sets. Now you are able to control the cable box from upstairs and watch your stations on both TVs.
on Jan 22, 2014 | Televison & Video
1998 nissan pathfinder oil pressure problems
Could be the oil pump.
Could be a major blockage in the lubrication system possibly due to major sludge build up.
Could be a faulty oil pressure relief valve.
1. How many miles are clocked up on the car?
2. How often does the engine oil and oil filter get changed in the car? Every 6000 miles for example.
Dec 24, 2012 | 1998 Nissan Pathfinder
Top end chattering sounds like rockers bike only has 11000 miles seems early to be the rockers chattering
This is not good. The sportsters, and Big Twins, all have hydraulic tappets and there should be no chattering coming from the rocker arms. The hydraulic tappets are designed to keep the rocker arms at zero backlash.
Oil pressure, keeps the tappets pumped up prevents the rockers from clattering loudly. If you have a major problem you will have a clearly audible clatter that you won't have to "try" to hear. You can hear them clatter from ten feet away. If you have to get your head down beside the rocker box to hear any "chattering" the rockers are making, this is normal. You simply can't have that much mechanical movement going on in there and not hear anything.
With the engine running, pull the oil filler plug out of the oil tank. Shine a flashlight into the tank and rev the engine up a bit. You should see oil squirting back into the tank from the return back towards the rear of the tank. If you don't see it, look for small foamy bubbles on top of the oil. If you see the oil returning to the tank or the surface of the oil is foamy looking and moving around, your oil system is operating properly. If you oil tank gets hot when you are riding the bike, your oil system is working fine. Harley engines employ a high volume low pressure oil system. The Sportster engine is probably the toughest engine Harley has ever invented.
Apr 28, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Problems withthe digital switchover and retuning my freeview box!
There are a few problems turning up as a result of the update. Do a factory settings on the box if it has the option to do so. Be aware of the actual transmitter you are on and the channels/frequencies it uses so when tuning you know whether its finding channels at the bottom, middle or top of the band. Sometimes you may need to unplug the aerial upto or after a particular channel to stop the box tuning unwanted transmitters. If you are picking more than 1 transmitter up you will often get extra channels in wrong locations
Nov 06, 2009 | Philips Televison & Video
I recently bought a Walkera 43g heli with a 2801 2.4 Ghz transmitter. The servos chatter and the heli is unflyable and very unstable and near-impossible to hover. I am experienced enough to flyout other...
This sounds like low power on the receiver BEC or the transmitter battery power. Check the voltages and cell polarities. You should not be getting interference with the 2.4 G system. If this is not the problem then I would send it back.
Aug 17, 2009 | Toys
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Chatterbox GMRS-X1 (15 Channels) 2-Way Radio Logo
131 people viewed this question
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
