Pixma MP210 printing on transparency paper.
Trying to print on transparency paper, printer preferences does not have a transparency paper to choose from. I have tried glossy, but the ink does not dry. Can you help me please
  • 3 more comments
  • scrapbooknut Apr 11, 2008
    I have tried using the photo paper and the ink is still not drying aven after about 1 hour. As it dries the printing is slowly fading off the paper.
  • scrapbooknut Apr 13, 2008
    pixma mp210 printer , i am trying to print on transparency paper. the ink does not dry, and after quite some time, you can see it slowly fading off the paper, where the print is. i am using the proper transparency paper, rough on one side and smooth on the other. any suggestions, please
  • 19,396 Answers
You need to chose photo/glossy
Posted on Apr 11, 2008
  • Ginko
    Ginko Apr 11, 2008
    Pixma MP210 in fact does not supprt transparent slides printing. The supported media type are: Envelopes, plain paper, card, photo paper, glossy.
    I suggest one of the other supported media type modes, eventually takeing care to let the document dry up. Try photo.
    If the ink does not fix on transparent prints at all, even using photo then I am afraid you will need to use a different printer on transparents acetate paper.
    Regards
  • Ginko
    Ginko Apr 13, 2008
    Dear sir ,
    I do not think using the proper transparency paper, this because unfortunately MP210 does not support transparents, therefore there is no transparency paper prescribed for mp210 in her specs (check your manual and settings, no transparents). Do not you think there must be a reason why you do not get transparent paper settings in any place in your printer settings, not either in the manual?
    You simply need to get a printer that supports transparent acetate paper, other than mp210, which does not support transparents.
    Regards
  • 3,037 Answers
You are printing on the rough side correct? Try switching the side of the paper that you are printing on and see if that helps at all. You should check your options and see if there may be an economical option or quick option and see if this helps put less ink on the paper. Please let me know how this works out for you.
Good luck
Posted on Apr 13, 2008
  • 156 Answers
Its worth a try to get something like this
quick drying papers ought to work for you..
its worth a try
Do i need both the colour cartridge and the black and white cartridge in the printer for the it to print on the black and white
you should be able to go to print preferences and choose fast economical ,greyscale- black ink only
Should be something like that most printers
Dec 07, 2014 | Canon PIXMA® MP210 Printer
How do i make the print darker on the black?
You could print in HIGH quality.
In your Printing Preferences page.
Select HIGH in Print Quality
Feb 27, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I get a e2 error and paper jams in on a angle how do i fix this proplem
Cancel the all print Que. Just go to Printing Preferences click cancel print. If possible restart the computer.
Feb 24, 2010 | Canon PIXMA MP210 InkJet Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Selecting cartridge
hi dear
set your printing to print in greyscale
open printer & faxs
select preference, choose coler
set to print in grayscale
oke
Mar 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
955 people viewed this question
jasbo
jasbo
