Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Code 88 I need to know what # to set my timer on I believe its a 3400 gallon pool ......Thanks
  • 297 Answers
Your timer will be different all of the time.
It depends on # of bathers how hot the day was how much sun did it rain and so on. you will need to play with it to get it right for you
check out the manual to get a general idea for you
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Jun 16, 2010
How much salt to put in 18x48 pool frist time
Frame Set or Easy Set?
If Frame Set = About 6,400 Gallons
If Easy Set = About 5,450 Gallons
Salt levels in a pool for a generator to operate efficiently...
2700 ppm Minimum to 3400 ppm Maximum, 3200 being Ideal.
So...
In pool water with NO Salt reading at all - 0, then you will add 2.67 lbs. of "Pool Salt" (which is almost Food Grade Quality! - NOT Softener Salt!) per 100 gallons of capacity.
This chart has lots of useful info: take a look
https://www.hayward-pool.com/pdf/manuals/Salt&SwimChemistryGuide.pdf
Jun 19, 2014 | Intex 18' x 48" Easy Set Pool Package
How salt to use for start up for a 22 x 52 above ground pool
You need to know how much salt is currently in pool...
then what is total gallons of your pool?
Round pool? 22' round?
52" walls?
Use only Pure Pool Salt, NOT Softener salt!
2700 ppm to 3400 ppm is the range for ideal levels in your pool.
check out this link...
http://www.conelyco.com/images/saltchart.jpg
btw... Your pool, if what I asked above is correct, has 11,400 gallons
May 31, 2012 | Intex Automatic Salt Water System for ...
Code 88 stays on it hasnt gone off since i plugged it in
This is normal... From here, you must set your cycle time.....Follow these steps... Note: on the 8110 model, you must start your pump and set your pump timer first, then wait 15 minutes to sync your chlorinator to between the pump hrs. If the pump turns off before the chlorinator, you will get a low flow alarm...
If you can't read this, it's from your manual.. If you need help setting the timer, post asking for help setting timer... Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How many gallons of water the intex 15x36 pool holds?
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Jul 10, 2011 | Intex Easy Set Pool 15x36
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Forgot how to set the timer getting 88 dont know where to go from here
88 is filtering
When you want to generate chlorine hold down arrow till it beeps hold up arrow till it beeps now with up arrow set desired hours no repeat the steps listed above that will lock it in now wait for 2-10 minutes until second green light comes on
Jun 09, 2010 | Intex Automatic Salt Water System for ...
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
102 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
