Question about Maytag MZD2766GES Side by Side Refrigerator
I have a side by side refridgerator with water and ice despenser and it is not making ice. the fridge is only 2 years old, a guy came out and said the fan was burnt out, but having a look at it now it still rotates easily.But a new fan was installed. I still dont have ice? The temperture in the freezer is -18c and in the fridge it is 10c.The water filter was replaced only 1 month ago and there are no problems with water line from the water tap to the fridge. Can you help? Thanks Sherree
  • kateoci Sep 06, 2008
    I have the same problem. Unit less than two years old ad the ice maker simply quite. There is ice still in the unit that never flipped out.
    Genius:
  • 1,073 Answers
You may have a problem with the ice maker module, temps ok in the freezer and fridge, i would be looking for a ice maker problem first
Posted on Apr 10, 2008
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
When ice despenser in door is pushed, power dims, temp guages on fridge side go out and no ice. Water will despense but takes several trys to work. Ice maker works..
You have a supply voltage issue on your main board. This is located at the back of the refrigerator in a small compartment. You can get the part and replace it yourself, just make sure you un-plug the fridge before you start the project. It is pretty simple to do, so give it a shot.
Good luck!!
Jun 14, 2010 | GE Profile PSS26NGS Side by Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Our refridgerator is old
in the toe kick
or in the upper right corner of the fridge
Oct 03, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore no water
does the machine have a lock out button on the despenser that you can push to activate the water and ice
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
155 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
