Question about Toshiba 32AV600E 32 in. TV
I have a Toshiba 32AV600A which randomly scans through all tv chanels by itself, have to turn off and back on to reset, have removed power cord and also reset to factory settings. it also turned on by itself on one occasion. i have removed the batteries from the remote just in case it had a button stuck. any ideas? thankyou in advance.
    President:
  • 1,961 Answers
The solution for the problem is to reset the system.the reset button is located on the mainboard PCB..this is the only 1 switch found on the main board just press the switch twice and the system will be reset..to go to the mainboard remove the back cover of your tv and you can see the main board..
tnx hope this helps you.
please rate my help..
Posted on Jun 05, 2010
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jul 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Toshiba model 35D10 randomly turns itself off. requires unplugging/replugging at wall ooutlet to reset. problem has become more and more frequent.
replace flyback transformer (same type - equivalent will not work ) - this part's work is to supply voltage to TV TUBE - after 4 years ( 4 to 10 years - depending on usage ) this part becomes weak then in top brand TVs automatically TV senses this deffect & well in advance it shuts off TV to protect other components from getting damaged due to this flyback transformer ........... as on now in your case only flyback transformer is deffective - so replace it as early as possible ....... click below link for more details on how to replace it ......
http://www.fixya.com/support/t10123898-panasonic_ct_36hl43g_tv_just_turned
Oct 31, 2011 | Televison & Video
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
We can get analogue tv and foxtel chanels but we have lost all digital tv chanels. We have run a full scan but nothing happens
unplug the power cord plug from the tv then unplug the antenna cable look inside the antenna metal peace make sure the wires are not touching to each other first connect back the antenna plug then the power cord if its an interior antenna your problem is the antenna
Oct 17, 2010 | Sony BRAVIA KDL52XBR2 Television
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
57" Toshiba projection TV randomly turns itself off and on
Look for loose connections in the power supply (plug, socket).
Feb 25, 2010 | Toshiba 57H82 57" Rear Projection...
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
Feb 16, 2010 | LG 22LG30 22 in. LCD HDTV
LCD TV Randomly Powers off and then back on
I would worry about polterguists
j/k
Check your remote batteries.
I had a TV remote that would do some weird things when the batteries were dying, like the problems you describe.
Jun 15, 2009 | Norcent Technologies LT-2720 27 in....
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Toshiba 32AV600E 32 in. TV Logo
287 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
