Question about LG Galaxy Countertop Microwave Oven
NOT WARMING MY OVEN IS NOW NOT HEATING, POWER TIMER EVEN ROTATING TRY ALL WORKING BUT WHAT EVER I AM PUTING INSIDE GETING AS IT IS I MEAN WITHOUT WARMING.
  • LG Master
  • 909 Answers
I never encourage a non technician to repair microwaves as the internal voltage is truly dangerous. I will tell you that if you want a no noncence repair to your micro. then have the technician replace the magnatron:Capacitor and Hv Diode.(Will definately work well again.)Only problem, you need to identify the profile of the magnatron and wattage.)
Posted on Jun 05, 2010
Without any known event, the microwave clocked no longer keeps time and the microwave does not heat up food. The timer works and the tray rotates, but no heating.
You have 2 systems inside your microwave, one is working, one is not.
The working one has the electric motor to drive the turntable and the timer.
The other system includes the "magnetron", which is the heavy unit that makes the microwaves to cook the food.
A repairman can check the magnetron to see if it has failed, and there are a few units that have a replaceable fuse that could be blown.
You will not want to try to fix it yourself, without a good knowledge of such things, as there is often a capacitor inside, which can shock you really bad if you touch it in error.
God bless your efforts.
May 03, 2016 | Samsung SMH9151 Microwave Oven
Have power, turntable rotates, lights on, timer works, will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 19, 2011 | Goldstar MV-1615 Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
The microwave will not heat the food
Yes - please buy a new one.
Unfortunately microwaves have 2 positions - working or dead!.
The cost to resurrect from the dead is all out of proportion with the cost of buying a new one which will have at least a 12mths guarantee
Jun 08, 2010 | Frigidaire FMV156DC Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
My microwave is no longer putting out any heat
The problem could be caused:
top door micro-switch
or
Answer: First, make sure your microwave is plugged in and getting an ample supply of power. If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate.
If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Warning: Microwave ovens are probably the most dangerous of consumer appliances to service due to the very high voltages (up to 5000 V) at potentially very high currents. If you have any doubts about your knowledge and abilities, replace the oven or have it professionally repaired.
Oct 06, 2009 | KitchenAid KCMS185J Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Doesn't heat or make noise, but timers reduce in time
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jan 01, 2009 | GE JE1660 Microwave Oven
Microwave oven - Amana Model MVH220E
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | Amana MVH220E Microwave Oven
LG Galaxy Countertop Microwave Oven Logo
124 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
