Question about Boating
Spark plug gap setting for 90hp 2 stroke yamaha outboard
3 Suggested Answers
  • 5501 Answers
SOURCE: ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
Posted on Jul 10, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
My 90hp Mariner 2 stroke outboard will only turn over when plugs removed
Hey Bryan,
When you turn the engine over with the plugs out, does gas or other liquids come out of the spark plug holes?
reply to me..
Thanks
Jun 13, 2017 | Boating
Whats the spark plug gap on a 86 Yamaha YZ 2-stroke
Hi, Sal for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2006 YZ250 Spark plug gap Yamaha 2 Stroke
yz125 spark plug gap Yamaha 2 Stroke
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jul 23, 2016 | Yamaha Motorcycles
Whats the very best spark-plug for a 1995 90Hp Evinrude 2str V4
first things first. Go to supercheap, repco, auto barn and get your self a product called fuel stabiliser ( around $20.00 for about 150mls). I put in a standby generator and it keeps the fuel good for about 6 months. Next the plugs that you want will be a multi point plug (several earth electrodes coming of the earth to the centre electrode or non fouling plugs for the 2 stroke mixture) They will be available from any outboard marine shop. They come in different prices as to quality from around $7.50 to $15.00 for platinium plugs Plugs used in a car engine will not cut it so get the right plugs for outboard 2 strokes.
Nov 05, 2014 | Cars & Trucks
What is the yamaha spark gap for jet ski engines 1990 year
0.024
http://www.globaldenso.com/cgi-bin/global/plug/usa/pw/pw-plug.cgi?filename=pw-14.txt
Sep 01, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
Spark plug gap 1999 yamaha 30 hp 2 stroke
if its got a 10 after the letters and numbers on the plug then its 1mil !
Aug 07, 2014 | Ngk Spark Plugs For Outboard Engines Plug,...
What gap is used in 90hp mercury 1985 ,?
if you are using buhw-2 plugs then you cant gap them as they are perma gap and no electrode !
Jul 27, 2014 | Ngk Spark Plugs For Outboard Engines Plug,...
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
I need the spark plug gap for a 2001 Yamaha 115hp 4 stroke outboard.
For a 2001 Yamaha F115 4 stroke use NGK Plugs LFR6A-11 gapped between 0.039 and 0.043
May 09, 2009 | Yamaha 12V Air Pump
Boating Logo
807 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
