I have HP DL380 Server G4 their is no display on screen at the booting and nothing is showing on the screen.
  • 11,800 Answers
Are you sure it boots (all the leds are on and you can hear the disks spinning) ?
If yes then the most likely fault is with the motherboard. To test it remove all hard disks, connect a PCI video card and try to boot in the BIOS. If it fails then the motherboard has died.
If no then most likely the power source is faulty, replace it.
Posted on Jun 05, 2010
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
HP DL380 no display on screen
does the server power on?
When i purchased my first DL380 i had a simular issue, as it turns out the datacenter i had purchased the server from, had installed a ILO replica type card. if you have the same card installed (it will have a ethernet port, power port, and video port) , this can be causing the issue, also, the card will be located in the PCI-X Slot.
Jun 03, 2010 | HP Compaq ProLiant DL380 G4 Server
Is there any procedure to boot DL380 G4 in single mode ? Thanks
Connect the keyboard, mouse, monitor, network cable and power cord. press the power button on the front panel of the server. If the OS is installed the server will boot.
May 17, 2010 | HP Compaq ProLiant DL380 G4 Server
Hp DL 380 G4 no display on screen, all the status lights are green
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Dec 03, 2009 | HP Compaq ProLiant DL380 G4 Server
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Oct 21, 2009 | HP Compaq ProLiant DL380 G4 Server
HP DL380, drive 1 and 2 lights are not on, but 3 is. Can I swap new drives in those spots and it write automaticaly. Or is there and easy fix, I checked cables and connections, reset hardrives and powered...
Boot from HP Diagnostic Media (SmartStart CD)and check the status of Array.....or harddrives...
If showing any failed status or not supported..
Replace drives to check if new drives show status...
It could be because of Drives not intialise for Array..
Boot to Array Configuration Utility...during bootup and go to Intialise disks....
Use them
Oct 05, 2009 | HP Compaq ProLiant DL380 G4 Server
HP DL380 G4 could not boot up. Nothing display as well. What's wrong with that?
make sure there is no disk in cd rom drive if there remove it and also check the amber led in front panel which is indicating the problem still if you are not able then open it and check the ram. And the power connector in motherboard and also the cmos battery or reset the bios.
Sep 15, 2009 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
