Ok pulled the thing off the control panel there is a green box on both the inside and one still on the back of lid i just pulled off where do i find the codes and if a tech sheet is a bit of paper um theres not one there just box with coloured cords neatly running randomly out here and there ??
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting. By the sounds of it you have a Fisher and Paykel washing machine with a green computer and green keypad.Is that correct?On these machines there is no fault code list under the top cover.Please reply telling me how I can help you.If your machine is indicating a fault code in lights please let me know what lights are lit.hope this helps.
Posted on Jun 05, 2010
Where is the location of fuel pamp electric fuses
If Its under the hood
  • Raise the hood of your car and look near the battery for a black, plastic box. Unsnap the lid and raise the cover. On the inside of the lid there should be a schematic of the fuse orientation, and inside this box there should be an array of circuit breakers, fuses and relays arranged according to the schematic. One of the small, black relays is likely to control the fuel pump. Near the relay there is also typically a red, 10-amp fuse labeled "FUEL," "F/P" or "FUEL PUMP." If not, check under the dashboard.
If its under the Dashboard
  • Use a flashlight to look under the dashboard. In most cases, there should be a lower cover to access the fuse panel. Remove the cover with a small screwdriver and pull the lid off of the fuse panel. On the inside of the lid there should be a label that identifies the fuse arrangement, similar to the label on the power center under the hood. Look for the same lettering that designates the fuel pump fuse. If the fuse is not there, look in the specialty fuse panels.
Jun 11, 2014 | 1998 Lexus LX470
I need a fuse box diagram for a Saturn SL2 1999 so i can pull a fuse out
When you take the lid off the fuse panel under the hood, the diagram is on the underside of the lid. When you take the velcro panel off the inside fuse panel next to the passenger's left knee, the diagram is on the back of the panel.
Sep 19, 2011 | 1999 Saturn SL
Trying to take off the back and top control panel of my Kenmore Elite top load washing machine so I can replace the lid switch and timer, any help would be appreciated.
It is rare that a lid switch and timer both need replacing.
The 2 ends caps on the control panel will snap off.
Once they are removed,take out the 2 screws on the right and left front sides of the control panel that holds the panel to the top.
Fold the control panel to the rear of the machine.
Unplug the lid switch wire.
Remove the 2 S clips holding the rear panel to the cabinet.
Pull the cabinet forward to remove it.
The lid switch is then accessible inside the cabinet.
Reverse this procedure to re-assemble.
Jul 17, 2011 | Kenmore Washing Machines
How do you get the lid off to replace the lid switch.
remove the screws on each end of the control panel,some units you have to remove the end caps to get to the screws, then flip back the control panel it has plastic hinges so be careful,then you unplug the lid switch,remove the two clips with a screwdriver that hold the back on,open the lid and reach on the inside and pull the back towards you and lift off the base,replace the switch and reinstall!
Sep 02, 2010 | Kenmore 24902 Top Load Washer
Machine cames on for 3 seconds and cut of with two littel stripes
Hi paul.The lid switch is normally located inside the control box.the lid has an arm witch activates a lever when the lid is closed.Sometimes the the lever on the lid switch doesn't quite make electrical contact.you can open the control box,you may have to remove the lid first.Unplugged of course.when the lid & control box are removed you can examine inside the control box area,there you should find the lever attached to the lid switch.it should lift up & down & make 2 copper coloured metal contacts touch together.sometimes they need a little bending together to make them touch when the lid is closed.Hope that helps.
May 31, 2010 | LG WFT1071TP Top Load Washer
How do i take the front panel off the maytag washer MAV4758Aww s/# 27991360JV
pop off the end caps on the control panel and remove the screws ,,,then pull the panel slightly forward and flip it back ih has plastic hinges on top so be careful,,,, next unplug your lid switch,,,then remove the two clips holding the back to the base with a screwdriver,,, then open the lid reach inside the inner rim and pull the back towards you at about a 45degree angle and then lift the base off the frame ,,,look inside and pay attention how the base comes off the frame and it will be easier to put back together!
Mar 09, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Need to replace spin switch on Kenmore 110.26832690. Have switch but can't get to it.
you would need to remove the outter base,,,,first unplug machine,then remove the screws on the control panel each end,,some machines you have to remove the panel end caps to get at the screws,,,then pull the panel forward a bit and flip it back it has plastic hinges on top so be careful,,then you can unplug the lid switch,,pop off the 2 gold clips with a screwdriver that hold the base to the back panel,,,,then open the lid reach inside the rim pull the back of the base up and towards you and lift off ,,,if you look inside and pay attention to how it comes off the bottom frame it will be a whole lot easier to put back,,,once the base is off you can replace the lid switch then reinstall the base,,, don't forget to plug the switch back in!
Mar 07, 2010 | Kenmore Washing Machines
Inside panel does not light up.Which fuse do I replace and the location. I have the fuse box diagram, but I don't know how to read it.
I’m assuming that you are talking about your instrument panel lights.
First, make sure and check the dial on the dashboard to the left of the instrument panel. It controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness. If it accidently got turned all the way down, you will have no instrument lights.
If that isn’t the problem, the interior fuse box is underneath the dashboard on the driver's side. Remove the fuse box lid by swinging the lid down and pulling it straight out of its hinges.
Fuse number 30 (7.5 amp) controls your instrument lights.
Hope this helps you.
Oct 29, 2009 | 1997 Honda Civic
Kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
Aug 09, 2008 | Kyocera Mita FS-1920 Laser Printer
Green tint/hue to entire screen
The first thing I check for this problem when doing a service call is the screen control. It sounds like it needs to be turned down a bit. The screen controls are in the front of the set. Pull off the front speaker grill, you have to pull it off there are no screws and it's a little tough to pull. Remove the panel behind the speaker grill. The screen control is normally black with 6 controls. 3 controls labeled Focus and 3 controls labeled Screens. The center controls are for the green. Find the controls that are labeled Green and turn it counter clockwise until the black is not green anymore. If there is glue on the control, then, peel it off. You may have to adjust it a bit to get the right alignment. When the set is turned on, only use one hand inside the set.
Jul 07, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
