Question about Wacom (PTZ930AC) Graphic Tablet
Intuos 3 dead zone
I've had my Intuos 3 about ten months now and yesterday was surprised to notice a portion of it had become a "dead zone", entirely unresponsive to the pen. The dead zone is a horizontal strip about 2" tall running across the middle of the tablet. Reinstalling the driver does not seem to help at all.
  • 2 more comments
  • TKD Sketch May 20, 2008
    similar problem, have tried all the trouble shooting tricks. my dead zone its about the same size and is completely unresponsive to both pen and mouse.
    let me know if you get this one figured out.
  • Anonymous Nov 05, 2008
    My problem is similar, except the whole tablet is a dead zone, despite the fact that the blue light is on and everything.
  • Mini_Dougie Nov 19, 2008
    I've got the same problem at a Fujitsu Siemens Stylistic 4114.
    It seems some connections of the flex connector from the Wacom Sensor Board became faulty.
    Over the last weeks applying slight pressure to the screen fixed the problem for a while, but since yesterday the dead zones ae permanent.
    I've got a dead horizontal and vertical stripe.
    br
    d
  • francz Dec 22, 2008
    My tablet has a 2 inch strip across the bottom of the control surface as a dead zone. Running under Mac OS X 10.5.6
    Installing driver 6.1.0.-7 has not helped.
    Blue light is on.
SOURCE: Mildly annoying problem with pen pressure..
I FOUND THE SOLUTION!
reset ur brushes and itll all go back to pressure goodness
Posted on Jul 10, 2008
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
SOURCE: how to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Posted on Feb 22, 2009
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
SOURCE: Genius MousePen 6x8 pen drags as if I'm holding down mouse button
Listen up kiddos! I had this same problem and I was troubleshooting....apparently you have to make sure you uninstall the old drivers first and delete the directory entirely, before reinstalling the software.
So, UNPLUG THE TABLET! This is the part that screwed me up... then go to start > all programs > tablet > uninstall. Run the wizard, restart, go to my computer > local disk drive > program files and delete the Genius Tablet folder. Then, install the drivers again, reboot, THEN and ONLY THEN, should you plug your tablet back in.
Posted on Apr 11, 2009
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
2008 Saab turbo at idle with vibration?
The only thing I can this is a vacuum leak, either a hose or egr valve.
I hope this helps!
Nov 06, 2012 | 2008 Saab 9-3 2.0T
Samsung dryer DV218AEB shuts off in middle of dry cycle - "dead" mode
This is a sign of a bad motor. There is an overload protector on the motor that when the motor overheats it shuts the motor down.
May 01, 2012 | Samsung Dryers
Dead zone in my F610
i think its been dropped and this dead zone has damage to the screen or the connections so its a waste of time even trying to get it to work
Dec 02, 2011 | Genius G-Pen F610 (31100050100)
The Top portion of the Agitator won't spin.
This is a very simple fix, that's inexpensive and requires no special tools. It sounds like you need to replace your agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are part of the agitator cam assembly under the auger (top portion). These little plastic pieces do wear out with age, causing the slippage you are talking about. Replacements are available at appliancepartspros.com for about $5. For a little bit more, you can purchase the entire cam replacement kit (which includes the dogs, cam and seals) for around $11 or $12. Use your model number to begin your search criteria and locate these parts under the "Agitator Parts" section.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Aug 19, 2009 | Washing Machines
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
Wacom Intuos 3 unintentional double click
I've been having the same problem and I think I just figured it out.
I'm using a Wacom Intuos 3 on Windows Vista. I think one of the Windows automatic updates caused this problem. I've just been putting up with it for way too long when I finally thought to check the driver.
I started by going to the control panel and typing in "mouse" in the search box. Then I clicked on "change mouse click settings". When I selected the "hardware" tab across the top I noticed that Wacom Mouse was not highlighted. I selected it and clicked on the "properties" button. I clicked on the "driver" tab across the top and clicked on the "driver details" button. Then I selected the wacommousefilter.sys driver and chose "ok". After that my double click problem has stopped.
You can also download the newest driver by going here: http://www.wacom.com/downloads/drivers.php
I hope this helps anyone still having this problem.
Dec 29, 2008 | Wacom Intuos3 Graphic Tablet
Intuos 3 Keystroke and Touch Strip not working properly.
solution-------just try new drivers.
Jun 26, 2008 | Wacom Intuos3 Graphic Tablet
Wacom (PTZ930AC) Graphic Tablet Logo
831 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
