Question about Moen & One Handle Tub & Shower Faucet
How remove the broken bathtub cartridge(Moen 1222)
Hi, when I try to remove old bathtub cartridge ( Moen 1222) I broken the stem ( bronze) then I tried to drill to remove it but I can not. Could you show me how to remove the cartridge, so I can put the new one in.
Thanks.
  • ph_ailan Jun 07, 2010
    when I try to replace the old cartridge( Moen 1222) I can not remove escutcheon out even I've already unscrewed. could you let me know how to remove it so I can change the oldcartridge.
    Thanks.
  • 2,272 Answers
The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
Moen Cartridge Replacement Instructions
Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
TAPPING the Threads into the Cartridge:
Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 07, 2010
  • Charles Simon
    Charles Simon Sep 30, 2014
    procedure is correct but what happens if the cartridge housing breaks and will not come out the half i the back works but the housing towards th back is free sping an the olt will NOT lossen what can I do?
  • 516 Answers
  1. Step 1 Turn off the water at the house shutoff valve and open up a faucet that is lower than the tub faucet (usually one of the outside ones) to empty the pipes.
  2. Step 2 Remove the trim cap (the cap in the center of the handle) with a screwdriver or dull knife.
  3. Step 3 Use a screwdriver to remove the screw in the center of the handle and pull the handle off and the escutcheon (decorative trim around handle).
  4. Step 4 Pull off the stop tube.
  5. Step 5 Using needlenose pliers, remove the retaining clip.
  6. Step 6 If there is a threaded retaining ring over the cartridge, remove it by turning it counterclockwise.
  7. Step 7 Slide out the old cartridge.
  8. Removing Compression Faucets
  9. Step 1 Turn off the water at the house shutoff valve and open up a faucet that is lower than the tub faucet (usually one of the outside ones) to empty the pipes.
  10. Step 2 Remove the trim cap (the cap in the center of the handle) with a screwdriver or dull knife.
  11. Step 3 Use a screwdriver to remove the screw in the center of the handle and pull the handle off.
  12. Step 4 Remove the decorative ring (known as an escutcheon) from around the cartridge of the faucet. You may need to turn it with a pliers to remove it. Protect the metal with a cloth if you plan on reusing the faucet.
  13. Step 5 Use a deep socket wrench to remove the packing nut.
  14. Step 6 Pull out the cartridge with a pliers. Wiggle it up and down or side to side if it does not come out easily.
  15. Step 7 Repeat Steps 2 through 6 for the other two handles.
Posted on Jun 05, 2010
  • 2 more comments
  • ph_ailan Jun 05, 2010
    Hi.
    The problem That I have already broken the bronse part( stem) of the old cartridge. now I try to drill the bronze left but I still can not remove the old cartridge left inside. Could you tell what should I do?
    Thanks
  • gridcowboy Nov 19, 2010
    Locate a #6, (or size for your situation), "SCREW EXTRACTOR". The proper size extractor should fit approx. half way into the center of the "remaining/broken" part of the cartridge before reaching resistance. [Tip: Make sure the extractor is large/short enough as not to bottom out at the back of the mixing valve itself. This would require the next larger size extractor]. REMEMBER, a screw extractor works in a "counterclockwise" motion! With slow steady counterclockwise pressure on the extractor, hopefully the cartridge will turn/move
    PART 2
    cartridge will turn/move……
    last attempt;
How to remove cartridge that is stuck
Depending on what faucet you have.this is a common problem with old moen posi temp cartridges basically you need a hammer flat head screw driver needle nose pliers. Take it out one piece at a time but be careful not to damage the side walls of the valve
Dec 03, 2014 | Moen Plumbing
How do I remove the old one
First you must determine if your shower faucet is posi-temp or if it has a separate balancing spool. The posi-temp takes a 1222 cartridge and the other type takes a 1225 cartridge. Remove the handle. There is a horse shoe clip which is removed from the top of the cartridge. A cartridge puller is highly reccomended. There are two different kinds. On the brass stem inside the cart. there is a notch. Make note of its position as this determines which side hot and cold are on. Pull the cartridge by twisting back and forth while pulling. Lubricate the inside of the cartridge barrel with faucet grease. No motor oil, vaseline or WD-40! They all eat rubber. Insert cart. and retainer clip. Install handle.
Jun 07, 2014 | Moen & Replacement Cartridge
I am trying to replace an old push-n-lock trim kit for my bathtub and cannot remove the old one.
Can you email us a picture of what you have? if we can see what you have we may be able to address the issue with your jets.
sales@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 13, 2013 | Moen Lift and Turn Bathtub Drain...
Remove stem of moen shower cartridge,
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
Jan 08, 2012 | Moen Plumbing
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
How do you remove the old cartridge pn# 1222 after you have removed the temp. limit stop kit?
If you are referring to a Posi Temp cartridge they can be tough to remove from the valve body but there is a specific Moen 'puller' tool available. Basicially, once the 'U' shaped brass clip, which holds the cartridge on place is removed, the old cartridge (including the brass stem) will pull out completely. However they are frequently stuck in place and require some force to break free. A small plastic tool is included with the new cartridge - it isn't worth much, IMO but at least try it. Slide it over the stem so that it fits snuggly against the old cartridge and twist it with channel locks or crescent wrench. You may be successful in getting the cartridge to turn, one it does it will usually then pull out. Grasp the brass stem with vise grips/channel locks and pull the cartridge straight out. If it doesn't budge, you will likely need the specific tool mentioned above which screws into the stem (where the screw for the handle would normally fit) and is tightened down against the valve body. The pressure applied is similar to an auto. brake puller, pulling the valve out. Be careful in exerting any pressure against the valve body because it may not be adequately fastened to blocking inside the wall cavity and too much or excessive pulling may cause damage to the water supply lines.
Make sure before the install the new cartridge the valve body is clean and free of any build up. I usually take a little emery cloth and clean it out then flush the valve with water. Also use plenty of additional silicon/plumbers grease on all the black rubber seals before inserting it . Make sure it is not upside down and fits into the valve body all the way. The brass retaining clip is then re-inserted. Be careful not to lose it as a replacement is not included with the new valve and may not be easy to come by. Good luck!
Oct 25, 2010 | Moen & Replacement Cartridge
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
Moen faucet in bathtub that whistles and a very high pitch whine when shower is engaged recently purchased house and don't know model # how can I locate a relacement part
your cartridge's rubber's may be fluttering in water stream. causing the noise. had similar problem,and a new cart' solved problem.either #1222 or 1225 is possible # for new cart,' remove and take with you to hard ware store, or the home depot/lowe's
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Nov 19, 2009 | Moen & Replacement Cartridge
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
5,683 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
