Question about Onkyo TX-SR606 Receiver
Receiver has worked fine until someone messed with buttons and now I cannot get the vocals from the center channel to sound right. Maybe needs to be taken out of Theatre mode
Look on page 57 in the owners manual, it shows the differnt buttons on the remote control that will change the mode. There are five different modes to select
Click on the link below to view the Onkyo TX SR606 owners manual
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR606_En_A_Rev1.pdf?CFID=1054096&CFTOKEN=29821098&jsessionid=f030909fd42ba4878fc57f7b485327841782
http://www.us.onkyo.com/searchResults.cfm
Posted on Jun 05, 2010
When i listen to music on my receiver i can only hear the music i can barely hear the voices what would be the cause of this problem
Do you have a surround mode turned on? Most vocals will come through the center channel. If you have a surround mode selected, and no center channel speaker hooked up you will lose vocals.
Jan 16, 2013 | Pioneer VSX-515 Receiver
I have a stav3780 connected to an outdoor speaker and it sounds like the music and vocals are not in sync
What channels are you feeding the outdoor speakers; and are there center channel speakers some distance away that are still audible (which would introduce a time delay)?
Jul 03, 2011 | Optimus STAV-3770 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
The Graphic Equalizer pattern control is not working correctly - I can hardly hear the vocal on my CD's when playing even though I've selected vocal. Vocals are outplayed by background music.
That sounds more like a polarity, or phase problem. Make sure your speakers are hooked up correctly, with the correct colors going to (+) positive, and (-) negative. Make sure your rca connection are correct, and that every connection has a left and a right. No stereo-to-mono adapters.
Is setting to "vocal" an eq selection, or a "dolby" stereo selection?
Are you using a dolby surround stereo receiver with left, right, center, rear, etc.?? If so, try turning off any effects, or anything that would send signal to the center speaker.
Lastly, depending on what the source of your music is, it is possible if your connections or receiver settings are not correct...that the music upon playback will be out of polarity, meaning the vocal portion will cancel out. Combining left and right signal together can sometimes do this as well.
Apr 09, 2010 | Denon D-C30 Shelf System
Center channel port - no sound
did you have a speaker on that output already? if not you might have to enable the speaker output in the speaker setup of your amplifier, refer to the amp manual to get these posedures to enable it into the surround system, if yo here a lot of vocals cominig out of the left and right while watching maaterial with surround suong then this backs up enabling it.
cheers
Mar 21, 2010 | Pioneer VSX-305 Receiver
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
No dialog sound when watching DVD's
The problem is that your center channel is not functioning correctly.  Dialogue is typically routed to the center channel only in 5.1, so if you don't have a working center channel all you will get is sound FX and background sound.
Go through all your settings, verify that they are correct.  Verify that your center channel is working properly, and wired to the correct output.
Test the center channel speaker and I feel confident you will find something amiss.
Dec 09, 2007 | Koss KS2503 System
Onkyo TX-SR606 Receiver Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
