Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
I am having difficulty removing the pump body from a Flotec, 1/2 HP, shallow well pump, FP4012-10 to repair/replace the pump body, which was cracked due to freezing. What steps do I need to take after removing the four large bolts which hold the housing to the motor? Thank you for your help.
  • 104 Answers
SOURCE: finding Flotec impeller for a flotec pump modle FP4012
WW Graingers. Call them with model and serial #s. If you do not have an account with WW, These guys have what ever you need:
http://www.pumpagents.com/partpages/FlotecPumps/FP4012.html
Posted on Feb 07, 2009
  • 83 Answers
SOURCE: convert a Flotec Flotec FP4012 pump from 110 volts to 240 volts
Here is a link to your manual.
http://www.flotecpump.com/pdf/FP745.pdf
Posted on Mar 30, 2009
gary1121
  • 332 Answers
SOURCE: The plastic part that houses the impeller cracked
you would have to contact flotec----there should be a part for it,, depending on the age of it, they change the covers all the time to get people to have to replace the whole unit
Posted on Jun 21, 2009
  • 12173 Answers
SOURCE: I need a motor for flotec shallow well pump unit
electrical supply companies plumbing supply companies grainger supply catalog or call 800 number for flotec will need horsepower make and model number from motor also for match up
Posted on Oct 27, 2009
  • 5603 Answers
SOURCE: hi there my flotec 1/2 hp shallow well jet pump
If it is on the pressure side about the only repair would be to get it welded. If on the suction side you MIGHT be able to "V" it out slightly and use JB Weld or maybe even Bondo... Tose will NOT work on the pressure side however.
Posted on Dec 13, 2010
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
Hi there my flotec 1/2 hp shallow well jet pump has a crack in the casing how can i repair this until i can get a new pump?
Dec 13, 2010 | Flotec Corrosion Resistant Shallow Well...
What value starter capacitor for 1/6 hp Flotec sump
when a motor burns out this will happen , replace the pump.
Apr 02, 2010 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
The plastic part that houses the impeller cracked on my flotec fp4012-001. Is there a replacement part?
Jun 21, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
69 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
