Question about Car Audio & Video
Hi ihave a repeller car alarm and the remote is busted i've just replaced the battery in the car and now the alarm has turned it's self on and won't let me start the car < i don't have the key for the alram either as i bought the car second hand , so i need to know how to override it please Regards, ken Ames
  • 1,498 Answers
Hi Kransky69,
What we are going to do is locate where the alarm is intercepting the power to the starter and bypass it. Essentially putting the start circuit back the way it was before the alarm was installed.
The alarm brain is usually either under the hood or under the dash zip tied to the steering column (so it can detect vibration to the ignition).
You need to find it.
Once it is located, there will be a legend on it telling you which wires do what. It will also probably be where you can't read it. No biggie if you can't. If you can, you're looking for start kill or disable.
What you are looking for are two wires, probably the same color. One is coming from the steering column (ignition switch). The other going to the starter. There is a relay (either internal or external to the brain) that disables the starter. These wires, when you find them, need to be connected each other.
Different cars, makes and models have different colors wires. You'll know them.
Best regards
Mike
Posted on Jun 05, 2010
  • Justin Case
    Justin Case Jun 05, 2010
    Sorry about the cut off.
    connected each other. This can be done with alligator clip jumpers or just pulling them off, stripping them and twisting them together.
    different colors wires. You'll know they are correct if you have a meter or test light.
    • Check the two wires for voltage there should be none.
    • Then check the voltage with the key turned to start (may require a third hand)
    • Only one would have power with the alarm on and the key on start.
    These are the two you need to cross.
    Best regards
    Mike
The battery was changed on my car. after new one installed the alarm went off. the guy push the black button and turned the key. now the alarm wont work. how do i get it workind again? .
the guy pushed a button under my dash turned the key and car started
you need to know where that push button is under the dash
if you cant find it your self ... ring the place back for instructions
not nice but
you may have to get them to call out and show you or
tow the car back to where you got the battery fitted
Oct 11, 2016 | Cars & Trucks
Jaguar Problem cranks, stops cranking and alarm sounds
sounds like the anti theft chip is causing the problem,I belive the battery in your key or the remote sensor is the problem.my bosses battery was located in the key its self,had the same problem until the battery was replaced.
uses the same battery that a watch uses,the dealer or a jewelery repair shop is your best bet,Good luck,Gary
Oct 24, 2013 | Cars & Trucks
Hi all,I have a Ford focus 2004 tdci 1.8 and the immobiliser intermittently won't turn off,I've tried both keys and its still won't start.kind regards Dean
Ford products are sensitive to changes in Battery voltage. The system views low Voltage as an attempted theft and makes the Alarm go off.
Remove the Battery, return it with a full charge or new Battery. Some other symptoms would be slow cranking or clicking like a dead battery. The Antitheft reduces starter Voltage to around 7 Volts making starting nearly impossible.
Please rate my info. If all else fails, the Identity in the car memory may no longer match the identity on the car keys. You would need to have a Dealer rematch the keys to the car.
Dec 11, 2012 | Cars & Trucks
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
My alarm on a 2002 Jeep Liberty won`t switch off, i`ve now put new battery`s in the remove as i thought that might be the problem but no. please advice?
Did you do a hard reset on the brain? Disconnect the positive terminal on the battery and leave it disconnected for like 10 min. then reinstall the positive wire to the battery. If that doesnt work then there are two possibilities.
1. The remote is faulty 2. The brain or reciever is faulty.
seek service or a new alarm.
Aug 17, 2011 | 2002 Jeep Liberty
Stranded at a Christmas party. Alarm will not disarm. Remote not working. Help!
try replacing the battery in the remote if that dont work and you can use the key to get into the car pop the hood and unhook the battery then find the fuse for the alarm and pull it out there might be a problem with the alarm its self.
Dec 13, 2010 | 2005 Toyota Highlander
Keyless remote is not working & alarm goes off & won's turn off
before doing anything... use the key to unlock the door...then the alarm will not go off
Jul 20, 2010 | 2008 Nissan Sentra
Why does the alarm on my 2000 s type go off by it self
if you have the handbook try reseting the alarm then use the remote to lock/unlock car.....
or try this....with new batteries in the remotes. shut all doors/windows,lock car with key and hold key over for 30 secs,then using the remote unlock and hold down button on remote for 30 secs.if remotes not working then you will nneed to get them recoded to the car...
Mar 09, 2010 | 2000 Jaguar S-Type
The remote for my sytem apears to be working, but is not interfacing with the car. Do you have any ideas?
hi, you may start checking on the alarm fuse if its busted and if it is have it replaced. if still no luck then start looking for the alarm reset button, it may help. have a nice day
Feb 09, 2010 | Car Audio & Video
Factory Alarm won't stop once battery is replaced
put your key in the door and turn the key to either direction!!
Dec 07, 2008 | 2002 Chevrolet Cavalier Coupe
Car Audio & Video Logo
153 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
