Question about OKI C9500dxn Led Printer
Registration error 2
I'd like to know how to solve the Registration Error 2 message on an Okidata c9500.
  • chuparosa Dec 04, 2008
    In attempting to reset the consumables counters in Table 1, I mistakenly initialized Table 2. Now I have a Registration Error 2 message. Any help would be greatly appreciated.
Soulvisitor
  • 1113 Answers
SOURCE: Okidata C9500 DXN--Printing Issues
Your asking a bit much
1) - Power ON printer while holding both the + & - buttons until “OKIUSER” message appears in LCD.
2) - Press + or – button until “ENGINE DIAG MODE” is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or – button until “NV-RAM INITIAL” is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. .....
..........the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Posted on Nov 19, 2007
agapecpus
SOURCE: Ricoh Aficio Color Registration Error
I started a thread here about the problem. It might help. http://www.copytechnet.com/forums/ricoh-savin-gestetner/7221-ricoh-aficio-cl3500n-color-register-error.html#post18536
Posted on Jan 16, 2008
  • 78 Answers
SOURCE: OKIDATA C9500 WITH error 002
Error 002 is an cpu exception fault caused by a defective controllerboard (CU board)
When replacing this board remember to replace the eeprom on the controller from the old board to the new one.
Posted on Oct 09, 2008
  • 95 Answers
SOURCE: okidata c9500 paper jams between
If you are getting jams in the fuser or right after it the fuser is probly bad. I think there is a mylar upgrade that attaches to the toner sensor arms under the top cover(not an easy fix). It is also possible the drum unit or the toner cartridge could be bad.
Posted on Aug 09, 2009
  • 526 Answers
SOURCE: fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Posted on Aug 28, 2009
Testimonial: "Thanks for the advice SALES320 in that it ended up being a issue with the yellow drum unit."
I need to reset oki c9500 to factory settings
http://my.okidata.com/man-ml320-1turbo.nsf/MOCContents/029CDD66B74320C385256A6B004EE4FE
Nov 08, 2014 | Office Equipment & Supplies
Tip
Replacement drivers for the Phaser 7500
The print drive for this printer is horrible, and causes functunal print issues. The best and simplest work around for this is to not use the phaser 7500 driver. Answer coming next . . . Use the Okidata C9500 print driver. It works perfectly for the Phaser 7500. Now you know how to make it print properly
on May 10, 2012 | Xerox Computers & Internet
My OKidata c9500 makes a loud clicking sound when I try to print. Like a drum turning and maybe the contact is not
Similar problem in other Oki's
It's not a drum, I would check the ITB Belt. Known for binding failure.
Okidata didn't spend a whole lot of money/quality plastic/nylon bushings and parts associated with the drive roller and other associated part for their ITB Belt assembly.
I hope this helps,,,Steve
Oct 12, 2014 | Oki Electric Industry Okidata Corporation...
I am getting error message ' Load Tray 1, 024-910, Printer' but there is paper inside. Once we open tray and close, error message dissapears. Regards Melane
Make sure that after you add paper, that you tell the printer the right size paper. Chances are you accidently changed the paper size and the printer is letting you know that the "wrong" paper is in the tray. If you are using standard printer paper, be sure to change the paper settings back to "Letter"
Dec 08, 2010 | Dell 5110cn Laser Printer
Hi we have a okidata b930n whit the " panel locked " error we can't use the panel control. thanks
Panel locked message is set to prevent changes in the unit. Your IT person probably locked it. You may need a password to remove the lock. Neither manual gives a reset method.
See page 147 in the reference manual:
http://www.softcom.cz/Files/00067013-00488709.pdf
User Guide:
http://www.ta.cz/common/download/OKI_N_B930_ENG.pdf
You may have to call or email Okidata:
www.okiprintingsolutions.com/us support@okidata.com 1-800-OKI-DATA
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2010 | Office Equipment & Supplies
Okidata 5150n is printing blurred text
You can set the registration using the control panel in the front.
Aug 10, 2009 | OKI C5150n Led Printer
Okidata c9500 paper jams between
Aug 07, 2009 | Office Equipment & Supplies
OKIDATA C9500 WITH error 002 and the printer keeps rebooting itself
Oct 06, 2008 | OKI Office Equipment & Supplies
Color registration problem for Oki Data C9500
Brain-storm .... simple solution .... REPLACED Magenta Drum.... works as good as usual, but is still and always been out a little - very strange, depending on the stock, if I'm using a 10pt coated stock, color registration has always been a little out ( when the cyan and magenta are being used ((together)) - purple - dark blue etc ...)
Mar 31, 2008 | Computers & Internet
OKI C9500dxn Led Printer Logo
624 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
