Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel washer GW703 only letting water in spurts. takes forever to fill.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting. Sounds like you have an out of balance switch problem.This is the most likely cause on the information you have posted. 80% of the time it is the switch and about 20% of the time it is the rotor sensor which is attached to the motor.Just a question or two. Does your machine stop during filling and light up a series of lights and it starts to beep.If it does ,from left to right is it the 3rd and 6th or 1st and 7th etc please reply and I can guide you throe what action needs to be taken.
Posted on Jun 05, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel washer will not allow water in to fill the machine
Hello, unplug the washer and take the control panel out to access the water level switch again. Remove the pressure tube that goes to the tub. Then see if it still does the same thing, if when you remove the tube the washer will fill, that tube is partially clogged causing pressure to be trapped in the tube, clean it out. Note that if it start to fill unplug the washer because it will overflow with that tube pulled off.
Thanks
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Jan 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
222 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
