Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
What colour should your gas heater flame be - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
  • 494 Answers
It should be blue. If it's got orange tips, it's burning dust, If it's got yellow flames or tips, it may need the air shutter adjusted, regulator pressure adjusted, the vent unblocked or just a real good cleaning. Douglas
Posted on Jun 05, 2010
My Mr. Heater 10,000 BTU Natural Gas Blue Flame Vent Free Heater #VF10KBLUENG keeps going out soon after it is lit.
Yellow flame indicates insufficient air is being injected into the mixing chamber - air hole blocked or restricted maybe.
Yellow flames indicate a general lack of oxygen and also a yellow flame is dangerous as it is producing high levels of carbon monoxide.
Dec 26, 2017 | Mr. Heater Heating & Cooling
How high should the flame be in a kerosine heater
Adjust wick till nice Blue Flame, if wick to High flame turns White/Yellow. Turn down wick till Nice Blue Colour
Jan 11, 2016 | Heating & Cooling
My fire burns with an orange flame and is either on full heat or low heat, no inbetween so can't ajust heat properly, can I fix it myself and if so, how.
Don't know whether you can adjust to somewhere between low and high. However, the flame colour that you describe seems a bit off. I would have expected it to be bluer. The air/gas ratio might need adjusting and before you ask, I have no idea!
Jul 09, 2015 | Heating & Cooling
Richmond 5v40-7 gas water heater. Burner lights completely but flame is very low. Does not grow above 1/4 inch.
Is flame clear blue or yellow?
Yellow flame, clean the flame arrestor screen
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Flame is blue:
Low gas pressure.
Bad gas control valve.
Dirty combustion parts.
Clean the water heater parts and catch up on maintenance.-
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Nov 01, 2014 | Water Heaters
Natural gas shop heater blinks twice. sparks 3x's start full flame and shut off. replaced flame sensor already
These are the check / repair items listed for a 2 flash trouble code: 1. Gas supply off or gas supply
pressure too low.
2. Flame sense rod contaminated
or loose wire.
3. Gas valve switch is off or wires
are not connected.
4. Broken or cracked porcelain on
flame probe or spark ignitor.
Feb 25, 2014 | Sterling RF45 Propane Gas Heater (45,000...
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
On my patio heater the pilot light will light but goes out as soon as I release it, even after holding it down a long time. I can't get it to stay on to light the heater.
Check that the pilot light is directed at the thermocouple, a copper 'tube' that heats up when the pilot light is lit. You should be able to see a copper coloured small tube that the pilot light is directed at - if the pilot flame is not heating that tube then the main burner will not light.
If the thermocouple is being heated correctly, then it could be a fault with the thermocouple itself (can be replaced) or the gas valve.
If the pilot flame is not heating the end of the thermocouple you should be able to adjust its position so that the pilot flame is directed at it more accurately
Jan 18, 2011 | Rta International Patio Heater
The flame blew out in my heater how do I relight it. where is the pilot light?
hello,
what you will have to check on first of all is the wire connection if there are still in there position and all so if the element (heater )has not gone bad please check on this once them get back to me the element is in silver colour
pleae reply me tomorrow
thank you.
Jun 07, 2010 | Hayward H Series Pool & Spa Heater 400k...
Rinnai 556 F sputters when starting
As a licenced plumber the only thing I will suggest is to call someone and have them service the heater.
Gas is deadly, and it sounds like there is something blocking the injector port, causing the gas/air mixture to not mix properly, which will make the flame change colour and characteristics.
The burner may need to come out, the inlet gas pressure will need to be checked and other things.
The rinai heaters are also expensive, as you would know, and trying to fix it yourself is dangerous. Also, once serviced by a plumber you will have the peace of mind to know it has been serviced properly and will run well for many more years.
You will need to find a licenced gas fitter.
Dec 21, 2007 | Rinnai EnergySaver 556 Air Conditioner
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
750 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
