Question about Numark TTX Turntable
Turntable platter doesnt spin when you press start/stop
It powers on but is non-responsive and won't play or spin records. Have sent to Rockshop to be fixed but apparently they "can't" fix it and parts (they wouldn't tell us which ones) dont work and are no longer available.
    Champion:
  • 222 Answers
Is your turndable belt driven? If so replace the belt.
Posted on Jun 06, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Platter quit spinning
Sounds like the motor drive controller might be malfunctioning. An authorized Denon service center would have to take a look at it to make sure.
Apr 08, 2008 | Denon DN-S3500
Help
Lift up the platter underneath should be a belt (black rubberband) on the platter. Once you find it leave it there put the platter back on, pad off. With the player off put the belt over the brass motor spindle.
Dec 21, 2007 | Gem Sound DJ-2100 Turntable
Numark TTX Turntable Logo
389 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
