Question about Car Audio & Video
No sound from headphones from dvd player - Car Audio & Video
  • 19,396 Answers
Hi.
Ensure that the red and white audio cables to the display are properly connected.
Test headphones on different system.
Try turning off and turning back on the system with the headphones plugged.
Posted on Jun 05, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Posted on Apr 09, 2009
Not enough sound from the headphones.
Every time you add another set of headphones it will cut the power sent to each headphone down as the power is shared between all the headphones being used. If you need it louder simply use less headphones as the unit does not have enough power to run all 3 at the volume you desire.
Aug 08, 2009 | RCA DRC6331 Portable DVD Player
2005 Escalade DVD no sound through headphones
wireless sensor on unit is one of you prob its not picking up signal or head unit has fault
Jul 01, 2009 | Panasonic CY-VHD9500U Car DVD Player
Cant find headphone socket for rosen in-car dvd player
Hope this helps....
Mar 27, 2009 | Rosen A7 Car DVD Player
How do you work the sound on the DVD player?
I have a 2005 with DVD - but do not have the wireless headphones. I use the AUX button on the front radio to switch between FM/AM/and the DVD Player. I do have headphones jacks in the roof console by the DVD player, but have never used them.
Aug 06, 2008 | 2006 Chevrolet Uplander
IS-PDVD10
Check the headphone ports to make sure the port is functioning.
Insert and remove a headphone plug into the headphone jacks to mkake sure the headphone jack isn't stuck and cutting off the audio tot he speakers.
If you have no audio from the speakers or from the headphones, open the setup menu and navigate to SOUND or AUDIO and make sure you are set to PCM audio and not RAW.
If none of these solutions help, you have a problem with the player that is electrical and not easily repaired.
Jun 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Ford F150 DVD Player
i have a 2005 f-150 and it was bought used, no wireless headsets and remote but i learned if you push buttons 2 and 4 together on the cddeck you can use the radio through the speakers and the kids in the back can used the headphone jacks to listen to the dvd player.
Jan 25, 2008 | Car Audio & Video
Poor sound quality/Speakers not working
That might be because :
-Your using a burned DVD
-It's just a piece of shit
-You need new headphones
Dec 27, 2007 | Durabrand 8.5'' Portable DVD Player
There is no sound
Have you recently used headphones in this device? I have a portable DVD player that had a similar problem. It thought that headphones were plugged in and that turned the sound in the external speakers off. If i plugged in headphones the sound worked in them. So I jiggled the headphone plug in while in the jack and removed it and the sound came back on.
Dec 10, 2007 | Durabrand DUR7 Portable DVD Player
Sound wont work right /not much at all
Headphone connector is usually designed to pass audio to speakers when the headphones are disconnected. A corroded or bent connector will lose audio. Does the headphone audio level seem ok? Try inserting and removing the headphone jack several times to clean the connector.
Nov 30, 2007 | Protron PD-800 DVD Player
No sound whatsoever on my dvd player.
These units have a remote which provides controls not on the player itself. Be sure to check that the mute is not on. The other obvious question (but it still needs to be asked) is have you checked the volume control setting. When you move the control do you hear static or anything over the speakers which could indicate a bad volume control. Have you checked audio with headphones? If you have sound with headphones then you may have a loose connection in the speaker wiring or the headphone jack may be malfunctioning.
Feb 18, 2007 | Initial IDM-7110 Portable DVD Player
Car Audio & Video Logo
169 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
