Question about Electrolux EW1000i Front Load Washer
Hi there . hope someone can help. my washing machine. EW1080F with Error E50/ beep 5 times. this code not in the user guide. appreciate the help. Nader
5 Suggested Answers
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
  • 174 Answers
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
  • 79 Answers
SOURCE: I am getting an error
Try the Electrolux troubleshooter tool on their website: http://www.electrolux.co.uk/Support/Troubleshooter/
I put your model number in, followed the steps, and for E60 it just says the programme has been interrupted - allow the machine to cool down for 30 minutes before restarting.
Posted on Feb 05, 2011
dcramer531
  • 1654 Answers
SOURCE: We have just moved our
Has it ever started for you after the move? Because here is what I have on the E50 issue.
finally found the manufacturers list of fault codes for your unit.
This is what it has to say about your units fault code
5 Beeps / E50- Motor is overheated- Washer motor stops if overheated.- Wait 30 minutes for motor to cool down.
If it continues to give the E50 error code try unplugging the unit for 15 minuets. If that does not work then it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor has failed and will need to be replaced.
My Guess is that if it worked before the move with no issue then you jarred something around inside and it has come apart. Look for loose wires and harnesses that may have jarred loose on the move.
Posted on Aug 21, 2011
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Simpson 950 washing machine shows error code E50
hi there, i have the same machine and just got the E50 after son loaded the machine, ...
to correct it i pulled out the load of washing, turned machine off and also at the powerpoint for a couple of minutes...- if you do not turn off at the powerpoint , the machine will continue to give E50.
i then reloaded machine with half of sons load and had no problem after.
note: his jeans and jacket was wound tight around the agitator and the load was way too full.
hope this helps you. :)
Mar 02, 2012 | Simpson Washing Machines
Flashing E50
This website says it better than I can!
http://www.whitegoodshelp.co.uk/wordpress/zanussi-washing-machine-error-code-e50-also-occurs-on-some-john-lewis-washing-machines/
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 23, 2011 | Zanussi Washing Machines
I have a Kenmore 110.4751 It will periodically beep while washing clothes. I don't find any error codes visible. I don't find any explanation in the manuals for this condition.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite beeps all the time
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
Does not complete program
Mar 15, 2009 | Kenmore Washing Machines
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
Feb 17, 2009 | Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Washing machine not starting
Jan 03, 2009 | Washing Machines
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Electrolux EW1000i Front Load Washer Logo
241 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
