Question about Onkyo TX-SR606 Receiver
Vocals have echo - Onkyo TX-SR606 Receiver
  • 516 Answers
Depending on how long the delay effect is, a gate might help....
For very short delays, you're SOL........
Posted on Jun 05, 2010
How do i get reverb to vocals? phonic powerpod 1860 delux
Use use an echo or reverb chamber for live recording through a desk.
A recorded vocal can be processed using a digital recording program like Audacity which is free. In it you will find a re-verb plug in which will allow you to add this effect.
Audacity Free Audio Editor and Recorder
Apr 17, 2015 | Music
Eq for male vocal mic on mackie 1604 vlz3
There is no easy answer to this. It will depend on the mic, the speakers and the singer and genre amongst many other things. It will also probably be room dependent too although the overall eq should be able to take this out of the equation to a large extent.
Your best bet is to get someone to sweep the frequency on the mid range with a bit of positive and then a bit of negative eq to find where most affects your vocals then fine tune to your liking. Are you using a bit of reverb/chorus/echo as his can often, when used sparingly, enhance even a good singer. The biggest difference you'll probably find is from using different mics. The ubiquitous SM58 does not suit everyone but is robust, warm and forgiving but if you're after a more pure sound there are many more accurate mics you can try.
Aug 10, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
Dec 09, 2011 | Behringer XENYX 2442FX Mixer
So when I listen with my headphones now, they only play the background music (if that makes sense). The music is almost echo-y and sounds far away. I rarely get the main music/singer, and if I do hear...
leezamastre,
It sounds like this might be a setting on whichever MP3 player, or sound device that you are using. You should check for an "EQ" on your device and try setting it to a different setting to make it so you can hear the music and vocals of a song.
Please let me know if you have any other questions about this,
Cheers,
Garbanian
Aug 08, 2011 | Skull Candy Audio Players & Recorders
When Im done recording and replay it, there are parts that have glitches and repeat itself. What do I do? I checked everything and everything seems to be ok. Im not sure how I can fix it.
Do you mean you're hearing reverb (echo) of recording? If your recording music or vocals make sure playback speakers are off when doing so. If you leave them on, you're recording multiple times IE: ECHO
Mar 07, 2011 | Blue Microphones Snowball Professional...
The sounds is making an echo when it gets to loud
As long as these headphones are not the wireless type. Then your problem sounds like the earth connection has become detached. Perhaps at the plug/jack end. If you can't solve it cut the ******** and fit a new one.
Jan 30, 2010 | Sony MDR-XD200 Consumer Headphones
Mach Speed Eclipse: No Vocals!!
This is caused by the grounding connection on the earphone socket becoming disconnected, either due to faulty earphones or poor soldering.
If changing the earphones does not work, then the only fix is to dismantle the player and re-solder the headphone socket connections.
Aug 03, 2009 | Audio Players & Recorders
Same thing
check the headphone is fully in the jack
Jun 09, 2009 | iRiver X20 MP3 Player
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Onkyo TX-SR606 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
