Question about Sansui DTV2760 27" TV
Starting problem my tv is not getting started
  • Sansui Master
  • 1,213 Answers
I can't say enough about bad capacitors.I have not repaired this particular model,But I will tell you this. This brand of TV is manufactured with under sized capacitors. They are are small and rated at 85 degrees. If you have a cap checker you can find these. There are about 8 or 9 bad caps here. Half may be located near the vertical IC. The rest in the horizontal section and may be the standby circuit! I would replace them with a high temp cap at 105 degrees and with the same Microfaret and voltage. Good Luck and thanks for asking!
Posted on Jun 05, 2010
How to start the tv?
Unplug both ends of the power cord wait 30 seconds then plug it back into the tv first then the power outlet and start the tv
Jan 17, 2018 | The Computers & Internet
I can not get no responce from my tv it just keeps saying your digital tv will start shortly and nothing
Reboot both set and a box if used by removing them from power for several minutes.
Dec 12, 2012 | Televison & Video
I have a problem with getting the tv started (power on). When we first got the tv 5 years ago it would not start with the global power on button on the remote. We would have to move the botton on the...
Most likely you have the problem in the power supply. In most cases you can actually see small capacitors swollen . IF you replace these with new ones your problem will likely be solved. It does require soldering.
Feb 21, 2011 | RCA L32WD12 32 in. LCD HDTV
I have a tv-20'inch Powervision----starting prob----In morning while starting stand by LED flikers and tv does'nt get started-----After repeated on/off tv gets started----there after no problem is face.But...
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options . 1. 1.Have it fixed by a professional 2. 2.Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board 3. 3.Remove and then replace individual faultycaps. This takes some solderingskill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
Hope this helps
Dec 10, 2010 | Philips Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to get the TV to start up using AUX 6 (HDMI)
menu 1325 hotel menu then select what channel to start on
Oct 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Picture while booting up, lost when home is loaded
The PC to TV converter is not setup for the correct conversion. When PC's start up, they use 800x600 screens which is close to TV standard, and they can synch. If the PC is set for a much higher resolution for a monitor, it is too far off to display. Check the converter. Or set the display settings to 800x600.
Oct 08, 2009 | KWorld PC to TV (0872880887527) Video...
Sansui DTV2760 27" TV Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
