Question about Linksys WAG200G Router
Plss help how to change the gateway ip of my computer
    Scholar:
  • 62 Answers
The gateway is given by your service provider so you could not change that
Posted on Jun 05, 2010
  • Annabelle Frigillana
    Annabelle Frigillana Jun 05, 2010
    after answering you awhile ago and thought of it harder and realized, it is possible, so i googled it:
    enter router settings, go to setup then advanced routing and there you can find the gateway
    check also the manual of your router
Need a batch file to change the ip and gateway as well as the computer name
Ip addresses are controled by your isp contact them and see if they will help you to change it. You don't need a file to change the computer name right click on Computer choose properties. On the upper left side click on Advanced System Settings. In the new window click on Computer name. Click on change computer name . After you changed the name make sure you reboot then your computer name will be changed to what you changed it too.
Terry
May 13, 2014 | Microsoft Windows 7 Ultimate for PC
How to gateway ping
jaykid18
The first thing you to check is to see if you are able to ping through your computer firewall. This link will help you check this.
How to allow ping (ICMP Echo) request through Windows 7 Firewall
Next you will need to know what the IP address of you Gateway is. If you do not know what it is the link below will help you find out what your Gateway IP address is.
http://www.fixya.com/support/r4935363-determine_computers_ip_address
After you have the IP address to your Gateway you will need to ping the address. If you need help doing this link will help you do this.
http://www.fixya.com/support/r6097326-ping_ip_address_in_windows
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 21, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a MacIntosh computer and wanted to install NetGear WGPS606 54 Mbps Wireless Print Server w/4 Port Switch to serve a Canon Pixma MP830. The hangup is the IP address assigned to the printer. I had...
You can assign ip with 2 method 1 is manually and other is automatic .
If you set manualy ip you must need to set gateway as your printers and other computer's gateway.
Subnetmask is same in all system.
For example if your netgear lan ip is 192.168.1.1 then your printer ip 192.168.1.5 sunet mask as 255.255.255.0 and gateway is 192.168.1.1
Other computer's ip 192.168.1.6 subnet mask 255.255.255.0 gateway 192.168.1.1
Make sure the printer driver installed and it is in network.
IF you want ip from netgear then you need to enable dhcp in it.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1 or
http://192.168.0.1 or
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on dhcp then enable save settings and restart netgear.
Then in printer set ip get automatic from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 14, 2010 | Computers & Internet
How to change default gateway
Default gateway is the IP address of the router.
Connect the computer to the router.
Open the setup page of the router using the current default gateway number.
On the setup page of tghe router, you will see the router local IP address.
You will find the current IP address of the router there.
If you want to change the default gateway, you can change the router Local IP address.
Make sure that it will be a private IP address only and not the public IP address.
suppose the current default gateway is 192.168.1.1.
You can change it to 192.168.x.y. X and Y will be the number between 0 to 254.
Click Here for more information about the routers and network
Jul 03, 2010 | NetGear DG834G Router
IP address for the router was changed to a number I do not know. Is there a way to get back to 192.168.2.1?
Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router.
Check the Ip address and default gateway. default gateway will be the current Ip address of your router.
Once you open the router set up page with the current IP address , you will be able to change the IP address of the router
Click Here for more information about the router and network
Jan 25, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
Reset ip , how
You can reset your router to factory defualts.
For that press RESET button for 10 seconds .
Reset button is in back panel of router.
Press it for 10 seconds.
Then connect router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
thne you can see configuration of your router.
Then you can change ip addreses in WAN settings.
Let me know if you need more assistance.
Nov 07, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
I cant seem to figure out what is the IP address for my MSI RG60SE router.....
By default ip address is 192.168.1.1
or
192.168.0.1
But if your ip is different and if in your router DHCP is enabled then you have to check your computer ip address with which your router is connect.
Go to start menu then type in run "ipconfig /all"
then check gateway ip it is your router ip.
Also you can check your ip wtih phone reciver connect your phone receiver to router with phone line jack.
Then press * so you can listen configuration.
Let me kow if you need more assistanse.
Thanks.
Sep 24, 2009 | Computers & Internet
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Need help plss
Thake a look at this website, might be able to help you. http://www.electronicrepairguide.com/
Mar 23, 2008 | Gateway FPD2275W LCD Monitor
Linksys WAG200G Router  Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
