Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check next?
  • 36 Answers
Try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Posted on Jun 05, 2010
Craftsman 21 hp 42in.deck model nimber 944.600110 white smoke
check the oil if it smells like gas change the needle valve and seat in the carb and change the oil
May 17, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
It Starts and runs fine for about 15 minutes then
I think that your right. Sounds like your ignition coil witch is most likely located under the the flywheel cover. I know that on some briggs and stratton engines they are actually under the flywheel, just trace the sparkplug wires to know for sure. When the ignition coil beginns to fail they start slowly (spitting and sputtering) and then they get to the point to where they stop firing after getting heated up and adventually quit all together.
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
May 07, 2009 | Electrical Supplies
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
317 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
