Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do I remove the top panel of the Whirlpool Cabrio washing mac
The top panel of my Cabrio washing machine has rusted out close to the bleach cup. I have a replacement top, but I can't see how to remove it. Once I get the top up, I think I can figure out the rest. I know many machines will have a spring-loaded clip you trip with a putty knife. I can't find it on this machine. Any advise would help. Thanks.
  • Anonymous Mar 16, 2014
    Can't figure out how to take off the top of the washing machine to replace the lid switch. I don't think the end caps pop off and it is tight to slide a putty knife in between to get to the clips
  • 24 Answers
To gain access to a Cabrio washer, use a putty knife to press inward on the 2 spring clips located where the washer top meets the washer's front/side wrap around case. Standing in front of the washer, measure approximately 3 inches inward from the outside of the case. It helps if you get eye level with the line where the top meets the case and shine a flashlight in the crack. You should be able to see the clips. Press in on both of them and the top should lift.
Posted on Jun 05, 2010
Testimonial: "Great! That did the trick. Thanks. "
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
What do I do to stop the rusting?
Stop using bleach in the dispenser. Just put it in the tub after your wash machine has filled with water. The problem is, bleach eats away at the enamel and metal and if you don't have it sufficiently diluted with water, then it eats away at everything---really fast!
Oct 24, 2014 | Whirlpool Washing Machines
Rust around my bleach despenser and under the side of top where the despenser is help
Bleach tends to eat thru the paint and cause the rust. What I do on a call for this is to take the bleach cup out, sand the area and paint the area with appliance paint. Here is a link to the paint I use in case you want to do it. The only way to keep this from occurring again is try not to let the bleach get on the painted areas. I know this is hard to do on a washer but you can try to poor some water around the area of the bleach cup. If you should get the paint else where, be sure it is enamel appliance paint.
Nov 01, 2012 | Maytag PAV2300 Top Load Washer
I have a Cabrio washer model #WTW7340XWO. I have had 4 shirts ruined with bleached out spots all over them after washing in this machine. We use NO bleach in the detergent. What is wrong?
Hi
It seems that it needs cleaning... you can run your washer with nothing inside it at its hottest temperature setting with 2 cup of vinegar inside the unit. After this clean the drain pump assembly completely, also clean the drain hose and drain pump filter, the spots should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
May 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the Whirlpool Topload Cabrio washing machine and it will be a year old on Jan. 15, 2011. It is really starting to stink up my laundry room. I have run the wash cycle through with distilled vinegar...
Here is what I do. I run "Tide Washing Machine Cleaner" thru the washer first with HOT water. Then, I recommend running a rinse only with hot water & bleach to rinse the washer out really well and don't forget to leave the lid opened when the washer is not in use.
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the clean washer reminder light mean and what do I do to clean the machine? This washer was new in September, 09 and the light has been on for several weeks.
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset the indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Nov 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Odors, the machine smells very much like mildew
Cure 2 cups of bleach large load water setting, hot water let set 2hrs full of water run washer empty "no clothes just hot water" 2 times normal wash setting, repeat if nessary.Note : Not all of the water drains from a washer the water left in yours spoiled, bleach should take care of it.
Nov 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
849 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
