Question about Echo Garden
Hi, I have a Echo blower PB 461 LN and having problem starting the blower. Any suggestion? Thanks Imran
  • 63 Answers
SOURCE: echo pb-413 leaf blower not running properly
It doesn't appear to be getting enough fuel. Unscrew the "L" and"H" screws about an 1/8 to 1/4 turn. Also at the end of the season run it completely out of gas and you shouldn't have anymore carb problems.
Please rate if this helps-
Posted on Mar 23, 2009
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 708 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
slohry
  • 87 Answers
SOURCE: Echo PB 2100 Leaf Blower will not speed up
Remove the muffler and clean the exhaust port, spark arrestor screen and muffler intake.
Posted on Apr 09, 2009
SOURCE: I have a Echo PB-260L Blower. It starts fine then
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Posted on Nov 12, 2010
- how do I stop the piston from hitting the spark plug on my echo pb-251 blower?
You either have the wrong plug in it or the aluminium sealing washer is missing.
Feb 26, 2016 | Echo Pb-251 Leaf Blowers
Echo pb-250 starts but willnot stay runing
turn low speed screw on cab out 1turn when it stars adjust it to get best power
Jul 22, 2014 | Echo PB 250 LN Handheld Bower
Is there a way to fix a echo PB 4600 cdi module?
Hi, no sorry, it has to be replaced. Regards Phil.
Oct 31, 2011 | ECHO, Inc. PB-251C Handheld Blower
My echo pb-2100 gas blower has no spark and wont start whats anyone has an idea whats the problem
no spark sounds like the coil, but check the connections and any corrossion in the wires
Oct 13, 2010 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Oil gas mixture of model pb-2100 echo leaf blower
Mar 27, 2009 | ECHO, Inc. PB-251C Handheld Blower
Hi. How many wires come out off the handles
There are 2 wires. 1) ground and 1) to switch. It sounds like you have a bad switch.
Mar 07, 2009 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
59 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
