Question about Linksys WUSB300N Wireless Adapter
I'd wish to add an external antenna connector (type Rpsma) to my WUSB300N. Is there any layout of this adapter for studying how could be done this work? I would give this job to be done by a professional in electronic. Many thanks for your assistance. daniel
    Scholar:
  • 150 Answers
Hi Daniel,
Hope you will get enough information through the following link;
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124093
Regards,
Anirban Mazumdar
Posted on Jun 05, 2010
How do I uninstall Linksys wusb300N adapter drivers without the software? The drivers are conflicting with my new N-PCI adapter. Linksys says I need to remove the drivers from my registry? Need help on...
Assuming you are using mirosoft windows, open the control, open "add or Remove Programs" select the linksys software, and click on remove. Then restart the computer.
Aug 18, 2010 | Linksys WUSB300N Wireless Adapter
I want to use an external antenna. Is the antenna
There is a kit available which contains the antenna, mag mount, coax, and connector. OR if you already have your antenna, mag mount and coax, the connector alone is available. You should be able to get these from your local Motorola dealer.
best regards.
Dec 04, 2009 | Motorola Talkabout Distance DPS (10...
How to add external antenna to a GE 75300 GE Slim Spacemaker
the antenna is internal (I couldnt find an external adapter) - u need to open the top (20 or so screws). Theres a "pipe" thru the back that leads pretty straight into the antennae. Hook ur metal to the closest bundle and out the pipe.
My reception still isn't perfect, but you can listen to it. I moved the ac power code to the far side and gain some improvement as well.
Dec 03, 2009 | GE Spacemaker 75300 Shelf System
How do I hook up a VCR to a small Sanyo TV? Thank you
How you hook up the VCR depends on the connections available on the VCR and the TV.
The simplest method is to use a cable from the VCR's RF (antenna) output connector to the TV's antenna input connector and tune the TV to the VCR output channel (3 or 4). You might need to purchase an adapter to switch from the standard plug on the cable to whatever kind of external antenna connector is on the TV. If the set only has a built-in antenna and no external connection at all (which would be quite unusual), you need a "balun" transformer. This has a connector on one end for the cable from the VCR and a flat wire with two terminals on the other end. Attach one of the terminals to the set's antenna with a clip-on jumper wire. Radio Shack sells the parts.
If your VCR does not have RF output but just audio and video jacks, connect those to the TV's a/v inputs if it has them. Again, an adapter cable might be required.
If the TV doesn't have a/v input available, you need an RF converter. This takes the a/v signals from the VCR and produces a channel 3 or 4 output that you can connect to the TV as described above.
It sounds more complicated than it actually is. Once you look at the VCR and TV, and remember that outputs always go to inputs, it's usually pretty clear what needs to be done. If you still have troubles please post a follow-up comment and I'll try to help more.
Apr 22, 2009 | Televison & Video
How do I connect an external radio shack AM enhancer
I presume that you wish to connect an external antenna/aerial to a portable radio with no antenna connection. Wind several turns of your antenna wire around the telescopic antenna - should work ok!
Mar 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Jan 31, 2009 | Audio Players & Recorders
Toshiba
There are no connectinos for an external antenna on your laptop model sorry.here is a picture of what it looks like though: The connectors at the top for the antenna cables. If you know someone that is an electronics guru, then order another card ( just in case ) for about $15 + shipping, and have him/her connect
those wires to a TMC or SMA connector somehow. Otherwise,.. just buy a good quality USB Wi-Fi adapter with an external antenna. ( which wouldn't cost much more than the spare Toshiba card and less if you figure in what a good dB gain antenna costs)
Feb 24, 2008 | Toshiba Tecra M2-S730 Notebook
Wusb300n on hp pavillion desktop vista home
What type of PC is it, what type OS? Are you formillar with accessing your BIOS?
Nov 10, 2007 | Linksys WUSB300N Wireless Adapter
Just installed Linuxon my HP desktop. I want to connect to the internet
here is a link to a full layout on how to do wireless with Linux and HP. Good luck on your project:
http://www.hpl.hp.com/personal/Jean_Tourrilhes/Linux/
Oct 05, 2007 | Linksys WUSB300N Wireless Adapter
Linksys WUSB300N Wireless Adapter Logo
129 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
