Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
My dishwasher dispalys an F4 code.
It starts up ok with the standard humming coming from the unit but after about 2 - 3 minutes it stops and the code appears. At no stage does the water start to flow into the unit. I've cleared the code and tried a few different settings but the unit shuts down everytime and the water never starts.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace the fill valve...
Dishwasher Trouble No Water entering Dishwasher http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Jun 05, 2010
Does anyone know what the F4 fault is on my kitchen aid dishwasher? I can reset it and then start over or select another program, although after approx 1 minute the F4 error code comes up and I cannot see...
Check the drain hose. When you turn on a dishwasher, the first thing that it does is check the pump. If there is a drain issue then it stops.
Mar 02, 2014 | Dishwashers
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
Dishwasher stops after a couple of minutes and F4 shows on the display
the F4 problem in the Dishwasher is common, and the solution is often to replace the Water Indicator unit. This is because the light-action microswitch attached to the unit often loses its spring.
Replacement is HERE if required.
Also, dismantle the sensor unit to get all the "gunk" out. There can be a carpet of white goo covering the rubber diaphragm, get the thing out of the machine though the front bottom inspection cover.
May 08, 2010 | Bauknecht 24 in. GSF8971 Built-in...
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Feb 15, 2008 | Dishwashers
CODE F4 and washer not working
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Feb 01, 2008 | Whirlpool 24 in. ADG6962iX Built-in...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
114 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
