Question about Pyle PLAM2300 Car Amp
The 0 gauge wire i bought for my amp wont fit in my amps power or ground slots. the ring terminal that comes with it is way to big but at the same time the ring terminal is also to small for my battery terminal im completely stumped on what to do
  • 416 Answers
Strip the ends of your huge wire and untwist the wires and the should form a few smaller wire bundles, keep as much wire together than will easily fit into the amp and clip the rest. MAKE SURE THE WIRE IS CLIPPED CLOSE. IF IT TOUCHES THE AMP IT WILL SHORT!
As for the terminal, clip the ring off the wire and unwind the wire just as before. When you look at it the wires should look like little fingers. (should be seperated into small bundles) wrap these around the bolt (or as much of it as you can while still leaving room for the bolt to screw back in)
and thats it!!!!! just make sure you clip any excess wires. dont want to blow that new unit.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on Jun 05, 2010
  • jeeps599
    jeeps599 Feb 13, 2013
    hi i was wondering if you do that like trimming the wire do you lose powwer?????
Sony 500w xplod amp what size ground an power wires do i need? Because the ground wire an pwer wire i have wont fit.
It depends on how far from the battery is mounted from the amp. I would use 4 gauge for both power and ground. The grounding point should be about 18 inches from the amp. You could always use the 4 gauge to a Fused Distribution block and a short run(18" or less)of 8 gauge to the amp.
Jan 14, 2014 | Car Audio & Video
What size wire and how does it hook to thr unit rpkb-036jaz
Look at rating plate on side of unit for Volts, Amps, Watts.
Volts x amps = watts.
If unit is 240Volts, then you need double-pole 240Volt breaker
If unit is 8500 watts at max power, then 8500 watts divided by 240Volts = 35 amps.
What size breaker for 35 amps?
When electricians figure load rating for breakers, they use the 80% rule.
40 amp breaker x 80% = 32 amp safe maximum load for 40 amp breaker. Use 8 gauge wire with 40 amp breaker.
50 amp breaker x 80% = 40 amp safe maximum for 50 amp breaker. I use 6 gauge wire with 50 amp breaker.
60 amp breaker x 80% = 48 amp safe maximum for 60 amp breaker. Again, use 6 gauge wire with 60 amp breaker.
How to connect wires to unit.
First of all, all outdoor HVAC units require power cut off located next to unit.
This lets the mechanic, or service tech turn power off to work on unit, even if the mechanic does not have access to main breaker box.
Next, open unit to see where wires connect.
If unit has wires, then connect both hot wires from 240 breaker to the wires inside unit. Connect bare ground wire to green ground screw.
If unit has terminals. The terminals will be labeled L1 L2. Connect each hot wire from 240Volt breaker to either one of the screw terminals. Then bare ground goes to green ground screw.
Copy following links for basic illustrations connecting wires to terminals, and to breakers, and selecting wire size.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Jul 21, 2012 | Rheem R-410A Complete Split System Heat...
Can you show me a dieagram or wireing up a amp
The process is pretty much straight forward for any amp.
This is what you will need to get the job done:
15 ft- 4 gauge power wire (RED) with in-line fuse 3 ft - 4 Guage Ground wire (Brown) 15 ft - 12-16 Gauge Remote wire (Blue) 15 ft - RCA Wires Here are the steps:
  • BATT - (Battery +12v) - This will be a 4 guage red wire that you will run directly from your car battery to this Terminal. Be sure to buy a wire a with an inline fuse. This is the main power supply to your amp. Be careful 12 volts doesn't sound like much till you see it in action. I would do this wire last, last thing you want is a hot wire accidentally touching some bare metal.
  • GND - (Ground Wire) - This is the terminal you will use to ground the AMP. Run a 4 guage wire from this terminal and fasten it to some bare metal in your trunk. Not more than three feet.
  • RCOM /Remote - There will be a small gauge wire from the back of your stereo that will be the remote wire it will be blue, most stereos have this wire labeled. Its purpose is to send a signal to the amp to turn on when the radio is powered on.
  • RCA Wires - The location for these is not pictured above, on the back of your stereo there will be amp outputs. Your stereo will send all your low frequencies (Bass) to your amp using these wires. On the amp you will see where these wires will go. They are essential to have a system.
The best way to go about this is hook up the power, ground, and remote and test the Amp to see if it powers up. I have seen so many of my friends skip this step and they paid for it later. I hope this helps if you need any more help let me know.
Nov 25, 2010 | Car Audio & Video
I have 2 12" solobaricL7 kickers and a audiobahn2200HCT and the amp clips before it gets very loud. is my power wire too small?
You should be useing 4 gauge power wire from your battery to the fuse holder, and from the fuse holder to the amp also 4 gauge, make sure you are also useing a short (18 inches or less) 4 gauge ground wire also. Make sure you are providing a GOOD ground, try to ground to the frame!!!!!!!
If you cannot ground to the frame, connect to the body of the vehicle close to the amp,drill a hole where needed and scrape paint or any coating around the drilled hole, then solder a ring terminal onto the gound wire,then put a bolt,lock washer and nut through the ring terminal through the drilled hole and tighten sufficiently to the vehicle!!!
Also what comes to mind is make sure the subs are in good condition(not blown) make sure they move freely without any scratching from the voice coils as you depress the cones in and out!!!
Depending on the vehicle you made need to upgrade the alternator and battery.
Make sure the battery has good cables and ground also, no corrosion,loose clamps,etc.
Good luck !
Mar 14, 2010 | AudioBahn Immortal AWIS10P Subwoofer Car...
Protect mode on. All wiring is operative without incident. Power and all is working, but will not come out of protect mode and all fuses are brand new.
it could be one (or more) of several issues. ensure none of the speaker wires are connected to the ground of the car, or to each other. ensure the speakers are not blown. check to see if the amp comes on ok without the speaker wires hooked up. your battery may be low - check voltage at the power terminals of the amplifier to ensure you have operational voltage. you may not have a sufficient ground connection - ensure the ground wire is less than 18 inches, is of proper gauge (minimum 10 gauge, the lower the gauge the better), and is connected to a sturdy connection going right to the ground plane of the car - make sure the paint is scraped off from under the point at which the ground wire terminal is screwed to the ground.
Jan 17, 2010 | Boss Exxtreme BLX5000 2-Channel Amp -...
The fuses in my amp are good and so is my inline fuse from the batter, the thermal light is on but the amp is far from overheated. what can i do?
Not big enough gauge of ground wire. You should always match the ground wire gauge with your power wire gauge.
Dirty or burnt ground wire ends
Bad place of where ground wire connected
the load you on the amp might be lower that the lowest ohms it can handle...
Jan 15, 2010 | Scosche Industries Scosche High...
My light wont come on period.
the remote needs to be plugged in as well. it should be next to the power/ground terminals. put 12volts on it. lights should come on. if not amp is faulty.
Sep 07, 2009 | Pioneer GM-5200T Car Audio Amplifier
Wiring in a cd player and cant find which wires to plug in
Wiring the System:
Wiring is an important factor in your audio system. You need enough power cable to run from your car battery's positive terminal through the firewall to the amplifier. The thickness or gauge (AWG) of the power wire is very important because you want to make sure wire can handle the power demand of your system. To find out the right gauge you must ascertain the approximate current draw (in amperes) of your amplifier (or amplifiers). First, calculate the total power of each amp (multiply the number of channels by the number of RMS watts per channel). If you have multiple amps, add up the total power figures to arrive at a grand total. Second, double your grand total power figure. Finally, divide by 13.8 — the result is your system's approximate current draw in amperes. Be sure to install an in-line fuse or circuit breaker near the battery. Without one, an accidental short circuit could pose a fire hazard and damage your amp (not to mention your car). Your ground wire should be of the same gauge as your power wire and must make direct contact with the body of the car. Look for an existing bolt or screw that makes contact with the car body closest to the amp. Remove the bolt or screw, and scrape away any paint or grime. A star washer will help your ground wire maintain solid contact with the car body. Use a ring terminal on the end of the ground wire, to keep it securely fastened to the bolt or screw. If you cannot find a convenient ground screw or bolt, drill a hole for one. Be careful not to drill into the gas tank, a gas line, or a brake line. If you are grounding multiple components, try to ground each one separately, with about a half-inch of space between each of the grounding points. If you'd rather use a single bolt, place the ground for the most current-hungry component (probably the biggest amp) closest to the body of the car. Put the ground for the component that draws the least current (probably the electronic crossover) on top. The last wire you need for powering the amp is a turn-on lead. It does not need to be as thick as the power and ground wires (18 gauge should be fine). It runs from the remote turn-on lead at the back of your receiver to the remote terminal on the amp. When connecting these wires, be sure to use crimp-on spade or ring terminals to get the best signal transfer. Your car's alternator ampere rating determines how powerful an amplifier you can install. An alternator that cannot handle your power demand will hurt your systems output. Here is how to find out if your alternator can do the job for your system. Multiply the ampere rating by 40%, and you'll get a rough idea of how much power demand your car's system can handle. An alternator capable of producing 55-65 amperes is usually adequate for systems up to 350 watts RMS. A Japanese car with a 35-amp alternator can accommodate around 125 watts of power, while a German car with a 90-amp alternator can handle a 500-watt system. Heavy-duty capacitors connect to the power cable (just before it reaches your amplifier) and act as a buffer zone between your amp and your car's electrical system. They store up a reservoir of power that can supply the amplifier's peak demands (like a kick drum beat) without having to get current from the battery. Capacitors come in half or full Farad. You can use one or link as many as you want depending on what your system demands. Car audio competitors often replace their vehicle's alternators with heavy-duty upgrades to accommodate big power demands. An amp can be securely installed with just a few screws. But since amps can be sensitive to electrical and motor noise and because interference from the amp may affect your radio reception, try to mount it at least 3 feet away from the receiver. When working inside the trunk, tape over the latch, so you will not become trapped inside accidentally. If the amp is in the trunk, run the input signal leads down the same side of the car as any speaker wires you have installed. Run the power and turn-on leads down the other side of the car to avoid interference. Do not mount an amp or other car stereo components such as electronic crossovers or equalizers directly on steel — you will invite noise problems. Instead, mount the amp on a non-conductive board and mount the board to the car body (or use rubber grommets under the screws to isolate the amp). Before you drill the screw holes to mount your amp, hook it up and give it a test run. If the amp is operating correctly, with no engine noise, then proceed with the installation. There is also a safety issue here: Components that aren't securely mounted could break loose during an accident and injure someone as they fly through the passenger compartment. Use bolts and nuts or screws to secure amplifiers and other components to their mounting locations.
have a good day
Jun 12, 2009 | 1999 Ford Escort
I cant hook up my amp
Hello cesar199064,
These are the steps you required to install your amp and subs:
1) Purchase an amp wiring kit with 2 or 1/0 gauge power and ground wires.
2) Decide on a location to mount the amp where it will get proper airflow and will not interfere with operation of the vehicle. Closer to the battery is better. Decide on the location and install the sub enclosures.
3) Locate a place on the metal body of the vehicle within about 3" of your amp for the ground. Connect the ground wire to the amp ground terminal and to BARE METAL on the vehicle.
4) Run power wire from battery positive (+) using one of the amp kit ring terminals through a 100A fuseholder to the amp positive terminal. DO NOT install the fuse yet.
5) Run a "remote" wire from the remote turn-on lead (usually blue or blue/white) of your dash mounted head unit to the amp turn-on terminal. Run a set of RCA cables from the preamp or subwoofer outputs on the head unit to the amp inputs.
6) Run speaker wire, preferably at least 12-gauge, from the amp output terminals to your subs.
7) Check all of your wiring. Make sure that no insulation was damaged or peeled off during the running process. Make sure there are no loose strands touching adjacent terminals or bare metal.
8) Use a multimeter set to read "ohms" and test from the negative battery post to the amp ground terminal. You should read "0".
9) Install the fuse.
10) Turn on your head unit and listen to those big Kickers thump.
11) Adjust the amp settings according to your manual.
The best place I've found for in depth information on audio installs is The Install Doctor. You'll find step-by-step procedures, color photos, wiring details, and even the tools required. I recommend that you begin with the "tech docs" link and read through some of the PDF documents.
Hope this helps.
May 08, 2009 | Kicker ZX10001 Car Audio Amplifier
Amp runs with no ground
One thing is take the screws out that you have used to mount it. Obviously you have drilled into bare metal. The path that you have created for the ground was not designed for that kind of current which would explain some of the heat. It warns against doing that in the manual. I have this amp myself and it heats up and cuts out all of the time still. I do not believe it is a power problem. I have a 5 Farad cap. Make sure your main ground for your car has a big enough gauge wire and also, if you can afford it, buy better battery terminals.
Sep 20, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Pyle PLAM2300 Car Amp Logo
405 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
