Question about SanDisk Sansa c240 MP3 Player
My device will only allow 200 mb or so of file
Can not utilize entire GB of space
I used to be able to put 200 or so songs
I can now only put approx 70 or so.
any suggestions
  • sfavors3 Apr 10, 2008
    I resolved this issue.
    With some determination:
    Turn the device all
    Remove the battery
    Reinstall the battery
    Turn the device on
    Go to the Settings
    Reset all the Settings
    Then Format the settings
    Connect the Device to the Computer
    Go through the hardware installation
    Device should be showing entire GB of space.
  • cyber777 Apr 11, 2008
    i have song in the sansa c240 141 when i want to putmore in i get a error that it can't create a file i have formated so many times that i dont know what to do yes i have formated by the mp3 setting and by windows vista
  • 8,596 Answers
Turn the device all
Remove the battery
Turn the device on
Go to the Settings
Posted on Jun 23, 2008
My Seagate ST3200822AS 200 GB Hard Drive appears to only have 13.6 GB of disk space
When you look at the hard drive make certain you can see all the files including Hidden files. I suspect you might have either back up files on it, or system files.
To show the files to do this (In Windows 7) by opening windows Explorer and going to where it says "organise" and clicking on it then selecting "folder and Search options".
Click view, then select "show hidden files, folders and drives.
PLUS
Deselect by clicking it - "Hide protected operating system files"
Windows will warn you but click apply.
Next when you look at that drive all files will be shown.
You can then select and delete the files you want to get rid of.
REMEMBER to return the two above options to there correct settings when you have done or you could delete files on the rest of you system you need.
Alternatively.....
It should be possible to wipe all these hidden files, by doing a reformat of the drive.
May 19, 2017 | Seagate ST3200822AS 200 GB Hard Drive
I am having Nokia N73 Music Edition and it showing "Not enough memory to perform operation. Delete some data first". I faced this problem many times earlier. The memory status shows Approx 44...
Hello Sir !! Welcome to Fixya !! This is nothing to worry about.Sometimes this happens because of the virus in mobile phone which doesn't allows the phone to perform required actions.You need to reset your mobile phone in an order to make it work fine: To reset the mobile phone Follow the simple steps :
  • Enter *#7370# or *#7780#
  • Then enter the security code and allow phone to perform its required action.
And you are done.It will starts working fine. If this was helpful please rate or token of appreciation will be esteemed.
Mar 31, 2011 | Nokia N73 Cellular Phone
Can anyone help me, that Ipod capacity is differentiated into Audio, Others and Free space. Mine is a 4 gb ipod i have jus 200 songs in it, The capacity of audio is nearly 1gb, the others ccuupies nearly...
Others would be all other files and information, stuff like calendar entries, documents, applications, etc. Basically anything that's not a song.
-= Daft Tech /=-
Oct 21, 2009 | Apple iPod nano
My mp3 player won't download my music files
What you should try is backing up your unit, if there are songs from any other source on your player
other than the one main computer you use.
Determine whether the entire load is less than 2 GB and if so, then reformat your MP3 player to make
use of space from songs which, though deleted from your player, (such deletions only decapitate the
file header) still may occupy significant disk space which is at a premium on your player.
Totally reinstall your player and then load your music onto same, leaving some headroom (some portion
of 2 GB i.e. 100 to 500 MB) on your player to allow for streaming of your music, which will enhance your
enjoyment of same.
Apr 17, 2009 | iLO (2 GB) MP3 Player
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Ilo
Although it should be letting you download more than 424mb of files, there are only 2 things I can suggest:
  1. Try to open up the folder when you plug it into your computer. Search through the folders and see if there are files in there that may not be compatible with your mp3 player and therefore will not display.
  2. Check for duplicate files and that the size of the files is not misleading. I've had a problem where a certain song was displayed as being 2.56mb, I opened it on my computer before it was transfered and it was registered as 60mb because the track would continue to play for hours afterwards because of the file being inappropriately labeled at the ending point.
The fact that there is so much unused and unusable space on the mp3 is unusual, but you may have a problem also with your formatting. You DO have to leave some space in your mp3 player to leave room for the operation files of the mp3, so although it is labeled as having 2gb of space, you have to save at least a couple mb of space to let the system function. Hope this helps.
Jun 12, 2008 | iLO (2 GB) MP3 Player
Sansa m250 2GB file adding problems
Can't create directories directly on the m250. I've got about 1000 songs loaded (already broken into subdirectories) that take up 800 MB and the device claims that it's full. (Firmware is also updated to 4.1.08A)
Dec 26, 2007 | SanDisk Sansa m250 MP3 Player
Copy heavy files fail from iRiver to Hard-Drive
That is too many songs to transfer at once - transfer less at a time
Oct 10, 2007 | iRiver H10 MP3 Player
"formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Dec 04, 2006 | SanDisk Sansa c150 MP3 Player
Unable to delete files and recover unused space
This actually sounds a lot like the problem pointed out in 'can't delete songs on sansa m230', and I'll bet it's got the same solution (you can read my full explanation there, but I'll just give the gist of it here). The Sansa has two USB settings, 'Auto Detect' and 'MSC'; for some reason songs put on it through MSC aren't visible from the computer if it connects later using 'Auto Detect', and vice-versa. As such, try switching the USB setting from one to the other and see if that helps. If it doesn't then I don't know, but my guess is that it will. ^_^;
Oct 11, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
163 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
