Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7600AWW very loud spin.
Our 9 year old washer is very very loud when it spins. How do we change the bearing? Or how much will it cost to have it changed?
jsrock516
  • 5911 Answers
SOURCE: Maytag Atlantis Washing Machine
The loud squeak at the end of the spin cycle is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking (causing movement of the washer) went the spin cycle stops. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself. NOTE: There should be a warning label explaining this
You can find all your parts and information at repairclinic.com. Just type in your model number in the search menu.
The parts required to make the repairs aren't very expensive, but the tool required to do it can be a bit pricey. If you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good about providing the necessary instructions with their parts, however.
In summary this job involves the following steps:
1. Removal of the front case to access the washer interior.
2. Removal of the drive belt and pulley from underneath the washer.
3. Removal of the drain hoses from the wash tub.
4. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
5. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring.
Now, I am summarizing this job quite a bit. If this is something you wish to try to repair yourself, and you need more instructions, let me know. I hope this helps you.
Posted on Feb 09, 2008
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 7 Answers
SOURCE: Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Posted on Apr 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
Posted on May 17, 2009
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis MAV7600AWW not spinning at all
Most likely the bearing / cam kit that releases brake is worn and not doing its job.
Nov 14, 2017 | Maytag Atlantis MAV7551 Top Load Washer
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Have a Maytag washing machine MAV7600AWW.
sometime not always it wont spin also the water temp is more on the cold side
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
271 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
