Question about LG WM2487H Front Load Washer
Washer will not drain displays oe - LG WM2487H Front Load Washer
  • 3 Answers
SOURCE: OE displays and washer will not drain
I had the same problem, and ended up taking the front of the machine off, and removing the pump assembly. I then pulled the motors off and cleaned the impellers. It will now drain, the only problem that we still have, is that leaks. With the machine off, I poured a small pot of water into the drum, and it slowly leaks onto the floor. It has done this even before I pulled the pumps
Posted on Jul 12, 2008
  • 489 Answers
SOURCE: oe comes up on the display
The drain filter is located on the bottom left corner behind the little door.  Remove the door and the filter is located there.
Posted on Jul 23, 2008
SOURCE: oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Posted on Aug 15, 2008
  • 489 Answers
SOURCE: LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Posted on Sep 29, 2008
MNTECH
  • 1543 Answers
SOURCE: lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Posted on Oct 11, 2008
WHAT DOES OE MEAN ON DISPLAY ?
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Oct 06, 2011 | LG WM-2277HW Front Load Washer
What does oe mean
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
Washer will stop after rinse cycle and says OE. Then is will not drain rinse water.
Kevin
May 12, 2011 | LG Washing Machines
It won't drain...keeps stopping and says OE
Kevin
Dec 11, 2010 | LG WM-2277HW Front Load Washer
What does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 23, 2010 | LG WM2487H Front Load Washer
I am getting an OE code on the display. I changed
Make sure you check to see if anything is caught inside the drain line, or the bottom bellow (black hose that connects from the tub to the drain pump/motor.)
Mar 25, 2010 | LG WM2487H Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Hello there, what does OE mean in the display?
OE is a water drain error.
Please clean the filter.
front lower left hand corner behind little door.
If after cleaning the filter the washer still will not drain the drain pump may be defective.
Jan 15, 2010 | LG WM-2277HW Front Load Washer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Oct 14, 2009 | LG WM-2277HW Front Load Washer
LG WM2487H Front Load Washer Logo
107 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
