Question about Troy-Bilt Pony Garden Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't start
  • lkvance65 Jun 05, 2010
    The gas line appears clear, when I pulled it off the carb the gas runs quickly out from the tank through the line. I also blew out the carb, it still won't start. I think that maybe something in the carb linkage is messed up-when I push it up to on- it doesn't appeat to move anything-does anyone have a diagram of the carb linkage.
  • 36 Answers
Did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Posted on Jun 05, 2010
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Troy Built Tiller - How much oil does it take?
About a quart ... but dont overfill. There is a dip stick on the engine.
Aug 03, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
What motor oil does the troy bilt bronco use
10w-30 should work.it should say what oil to use on it
May 27, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt Pony Garden Tiller Logo
719 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
