Question about Jensen's VM9312 Car DVD Player
No sound i need help lol i hooked up this reciver and sounded good for about a day then later on after i shut the truck off and started it back all i got was my bass out put no door speakers
  • alanlegardo Dec 21, 2008
    i have the same problems...it says the headunit only takes 4 ohm speakers could the ohm load turn the headunit off i dont know. someone needs to help us out here.
No sound in my speakers!?...
Posted on Nov 03, 2008
Just installed vm9312 and there is no sound everthings else is working
Posted on Dec 23, 2008
2001 isuzu rodeo cold start
Sounds like EGR(Exhaust Gas Recirculation) issues. As this is a second-generation of OBD(On Board Diagnostics), it will need to be thoroughly inspected by somebody with a bi-directional scan tool.
Feb 01, 2014 | Cars & Trucks
91 accord wagon won't turn over
the alterator relay is not ingageing you need to have it replace see when it cool down it started back up the relay became un hooked dont for get to diconect the batteri cables first hope this helps
Dec 31, 2009 | 1991 Honda Accord
Reciver overload
More than likely, it's not a problem with the receiver. The fastest way to tell is to disconnect all speakers at the back of the receiver and turn it on. If it does not shut down, your receiver is ok and is just protecting itself from damage. If it stays on, check all your wiring, what it sounds like is that you have one or two braids of wire touching the other terminal. Not enough to cause a "short" at turn on, however, when you turn up the volume the resistance increases and creates a short, thus "overload" shows on the receiver. Hope this helps. If you need more help troubleshooting, post a comment and I can help more.
Aug 16, 2009 | Technics SA-DX930 Receiver
No Picture, No sound, No OSD, Stby light flashes 20 times
well intermittinly shutting down only thing i can say is go thru that board may be getting good reading on transistor pull them out recheck
sounds like a bad cap make sure nothing is soldered together start from the beginning good luck shad tv man
May 02, 2009 | Sony FD Trinitron KD-36XS955 36" TV
I have a scion xa and just hooked up a sub and amp to the stock system it was working good until i put the head unit back in place. Now im getting power and everything but no sound??? Took it apart again...
Same thing happened to me but also my CDs wouldnt come in or out, so i plug it back in and just leaved it alone. two days later it started working again. try it, it might work for you.
good luck
Nov 23, 2008 | Audio Players & Recorders
Sound turns on when it wants to.
disconnect all of your speakers , then hook them back up one at a time when the radio starts to malfunction u have located which channel on the radio is bad.check ur wire installattion
Aug 30, 2008 | JVC KD-S5050 CD Player
Satellite Receiver Malfunction
Go into the menu and check the signal strenth to see if its going up and down or if its a stead as a rock. I have seen this problem be the reciver as I was a satillite contractor for 5 years in the past and I have installed 1000's. I have also seen your poblem be a small brance in the distance cause the freezing, also a bad connector from the lnb on the dish to the multiswitch, or a bad connector on the back of the reciver or even a pinch in the wire but the most common thing I have found would be a loose connection on the back of the reciver with the fitting wasent screwed on all the way.. If the signal is rock steady, the reciver will need to be replaced as the recivers dont pay to be repaired. good Luck
Jul 31, 2006 | RCA DRD485RG DirecTV DTV Receiver
Receiver turns on and off in endless cycle
Its one of Three problems. The main b+ filter is defective, one of the standby power sources have a bad capacitor on the line, or theres a short in the main amp. section. Its probabvly going to cost you more then you would care to invest in a reciver thats around 5 to 6 years old. Its most likly time for you to upgrade to a suround sound dydtem with new fancy lights bells and whistles. Good Luck
Jul 29, 2006 | Onkyo TX-SV636 Receiver
Harmon kardon stereo reciever avr130
Say PLEASE!!!! LOL just pullin your leg. I have found most reciver remotes are a B&*&h to work with as well as program for other componets. Now for yor problem at hand. It could be a speaker partially shorted and on a high current such as a loud input to the speaker its loading down the reciver. Also could be a fault with the idle current or zero offset voltage, or an Idle bias alighnment, or fault in the recivers amp section. The only way to test this amp would be have a service tech hook up the amp. to some load resistors, hook it up to a scope, and insert an 400 cycle to 1000 cycle tone at .775 Millivolt and see when the outputs clip if at all, and this will tell an experienced tech where to look for the problem you describe. You see my freind there are no user serviceable parts inside this reciver for you to trouble shoot unless you know how to use specialized equipment and troubleshoot solid state electronics. Good Luck
Jul 01, 2006 | Harman Kardon AVR 130 Receiver
Jensen's VM9312 Car DVD Player Logo
203 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
