Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
How do i remove the lamp housing from the unit so that i can change the lamp?
  • 10,594 Answers
Following is lamp replacement procedure for Sony KDF-70XBR950 model as question post shows it.
Push and release upper cover of control panel on tv front where volume and channels buttons are located, you will see screw that need to be lose to remove this cover.
On left side of that cover, there is lamp cover, lose its screw and remove it, there you will see Lamp. Lose its hex screws with hex key and pull out old lamp. Insert new lamp and put things in reverse order to complete the job.
Click Sony Support to download lamp replacement procedure manual for same model for more details and exploded views that will help you more.
Thanks.
Posted on Jun 05, 2010
How do I change the lightbulb on a GE Monogram Microvae
The lamp is located inside the microwave housing which has to be removed to gain access for replacement. I agree with GE that removing the housing exposes you to dangerous voltages (even with power removed). The old lamp is removed from its socket and the new one installed, then the housing is reinstalled.
Mar 21, 2015 | GE Monogram ZEM200SF Microwave Oven
How do i replace a 2006 A6 rear light. I crashed into a wall in the ice and it broke the plastic. I have a full replacement unit.
Rear iignts in rear na, removing and instaiiing
Fig. 325: Rear Lights In Rear Lid, Removing And Installing
Courtesy of VOLKSWAGEN UNITED STATES, INC.
Removing
CAUTiON: • Switch off all electrical components.
. . Switch ignition off and remove ignition key.
o Turn light switch into "0" position.
o Open cap - 1 - for warning triangle.
o Rotate quick-release screw - 2 - counter-clockwise 90 C and remove cover - 3 - from luggage compartment lining - direction of arrow -
Fig. 326: Removing Bulb Socket From Housing, Pressing Catch Bracket Downward
o Disconnect electrical harness connector
o Remove bulb socket - 1 - from housing, press catch bracket - 2 - downward - arrow - to do so
Fig. 327: Identifying Nuts, Clamping Bracket, Inner Tail Lamp, And Clamp Mounting
o Unscrew nut - 2 - and remove clamping bracket - 1 -
o Remove nut - 4 - and remove inner tail lamp - 3 - toward outside
o Remove clamp mounting - 5 - from body cut-out
Fig. 328: Identifying Clamp Mounting, Nuts, Inner Tail Lamp, And Tabs
Installing
Installation is the reverse of removal, noting the following:
NOTE: • Make sure seal between body and tail lamp housing seals properly.
. Attach clamp mounting -2 - at inner tail lamp and screw on nut -3 - loosely.
. Attach inner tail lamp -4 - at body cut-out and make sure grip tabs - arrows - of clamp mounting rest against body cut-out
. Slide clamp mounting - 1 - onto threaded pin of inner tail lamp and tighten nuts - 3 - and -5 -.
Jan 19, 2011 | 2006 Audi A6
How to change a headlight lamp 2009 dodge ram
Disconnect and isolate the battery negative cable.
Remove the four plastic push-in fasteners that secure the upper radiator seal to the grille support and both fender ledges.
Remove the two plastic push-pin rivets that secure the upper radiator seal to the radiator.
Remove the upper radiator seal from the vehicle.
NOTE: It is not necessary to remove the grille from the front of the vehicle to service the front lamp units. The illustration shows the grille removed only to assist in clearly identifying the locations of the front lamp unit mounting provisions.
Remove the screw that secures the upper mounting tab of the front lamp unit to the Front End Module (FEM) carrier (also known as the radiator closure).
Using a socket with a magnetic insert or with a small piece of butyl tape inserted, reach down between the grille and the FEM carrier to access, remove and retrieve the screw that secures the lower mounting tab of the front lamp unit.
Remove the fastener that secures the tab at the bottom of the access panel to the front of the front wheel house splash shield.
NOTE: The illustration shows the back of right front lamp unit and slide lock with the slide lock in the locked position.
Reach through the access opening of the wheel house splash shield and lift the slide lock upward far enough to disengage it from the lock post integral to the back of the front lamp unit housing.
From the front of the vehicle, grasp the outboard edge of the front lamp unit firmly and pull it straight forward to disengage the ball stud from the plastic grommet in the FEM carrier.
Pull the lamp away from the front of the vehicle far enough to access and disconnect the two wire harness connections from the park/turn signal bulb socket and either the headlamp bulb on vehicles with dual headlamps, or from the headlamp pigtail wire harness on vehicles with quad headlamps.
Remove the front lamp unit from the vehicle.
Firmly grasp the headlamp bulb in the reflector through the opening on the back of the front lamp unit housing and rotate it counterclockwise about 30 degrees to unlock it.
Pull the bulb straight out from the keyed opening in the reflector.
Reverse order to install
Dec 22, 2010 | Dodge Ram 1500 Cars & Trucks
How do you get the brake light bulb out of the its holder?
Welcome to FIxYa.com
Parts:
3157 Brake light
How to Remove bulb:
Remove the Lamp unit from the end of the quarter panel.
"Open tailgate to access and remove the two screws that secure the inboard side of the rear lamp unit to the side of the tailgate. (see Figure) Pull the outboard side of the rear lamp unit rearward (away from the end of the quarter panel) far enough to unsnap the two ball studs on the outboard side of the lamp housing from the plastic nuts in the quarter panel."
Change Bulb:
See Figure
Regards, Lee Davidian
Thank you for using FixYa.com
Nov 05, 2010 | 2002 Jeep Liberty
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    How to remove rear light cover to change bulb
    298002.jpg 1. Disconnect and isolate the battery negative cable. 2. Open the liftgate to access and remove the two push-pins (3) that secure the rear lamp unit (1) to the side jamb (2) of the liftgate opening. 3. Pull the outboard side of the rear lamp unit rearward far enough to unsnap the two ball studs on the outboard side of the lamp housing from the two plastic grommets (6) in the quarter outer panel. 4. Pull the lamp away from the vehicle far enough to access and disengage the retainer on the body wire harness (4) from the tab on the lower lamp housing. 5. Disconnect the body wire harness connector from the pigtail wire connector (5) on the back of the lamp housing. 6. Remove the lamp from the lamp opening of the quarter outer panel.
    Hope this helps.
    Mar 26, 2009 | 2007 Jeep Commander Rocky Mountain
    Xl-2100u
  • Unplug your Projector from your power outlet
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Red?Green picture
    You may have inadvertantly loosened a cable connection to the DMD or logic board... You might be able to shut it down, unplug the unit and remove the lamp.. With the lamp out take a good flashlight and shine it into the lamp housing area inside the Tv and see if you have any wire obstructions that you could have contacted with the edge of the housing as you were removing or inserting the lamp...
    Bill
    Dec 18, 2007 | Toshiba 50H72 50" Rear Projection...
    How to change lamp in AGFA Arcus 2 flatbed scanner?
    http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
