Question about Frigidaire FAA065M7A Air Conditioner
My ac unit wont start up. i have checked the
My ac unit wont start up. i have checked the wiring it is ok. the unit powers up on the display but wont even run the fan
  • Frigidaire Master
  • 4,655 Answers
That could be many different things. If you would like working with me to get the answer then let me know. I will send a user manual and wiring diagram soon. I just want you to feel comfortable following through this with me, OK? Thanks, Sea Breeze
Posted on Jun 05, 2010
  • John Tripp
    John Tripp Jun 05, 2010
    Click Here=> FAA065M7A User Manual and Here=> Wiring Diagram Unplug and have a look at the start capacitor. Most time when bad they swell or buldge. Remember the wiring colors to herm, fan and common and have someone check the capacitance. It takes a special tool to do that they will check capacitor free at a local refrigeration parts supplies store. Sea Breeze
  • John Tripp
    After unplugging discharge the capacitor with a screwdriver because sometimes they hold a charge, Sorry I forgot to mention that, Sea Breeze
Weathermaker 9300ts wont turn on ac compressor. The insind blower is working The fuses at outside unit is good and yes power is there. the heater works. no flasing lights
How do you know power is at the outdoor unit? Did you check it with a meter? Check your breaker. If there's power at the outdoor unit, then shut the power and test your contacter. If the contacter has supply power then check the low voltage (24-28 volts) that operates the contacter, and if none check the low pressure cut-out,high pressure cut-out and make sure the thermostat is calling for cool. All ok so far, then test your capacitor. I forgot to mention to check for loose, broken, and disconnected wires.
Aug 24, 2013 | Carrier Heating & Cooling
Carrier 48NMX042 IFM wont stop, condenser fan motor and compressor wont run
Ok first thing is it sounds like a wiring problem. So first step is to make sure the thermostat is properly connected. Which... the main thing here is there needs to be 24v dc power coming from your control board (transformer) going to the thermostat..generally that is the red wire. All the thermostat does is connect that "red" wire (power) to one of the other wires to complete a circuit. So make sure you have 24 volts... (generally about .5amps) . if you have power than switch thermostat to fan only should energize the green wire only. then switch to ac and move temp low enough that the ac should turn on and that should energize the yellow wire. for sure one of those wires is incorrect now or the fan wouldn't be on OR THE THERMOSTAT IS NOT CONNECTING THEM AND IT IS BAD. Now about the compressor and fan.... those same wires run out to the compressor unit... ok the yellow for ac.. greeen does not go to compressor unit that is for fan only (vent).. red carries the same 24 volts... one difference here is that most carrier units only have the one transformer....so you run the red wire is the +pos 24 volt..and then a "common " wire is needed which is the Ground or neg... that wire on a carrier is brown usually but could be different depending installer. The orange wire goes to the pump reversing valve it is always energized when on ac mode...when heater is on in the winter it is heat pump and is not energized so just connect the orange and yellow together... tell me more specifics if this doesn't help and i'm sure I can help you... thanks Chuck
Jun 22, 2012 | Carrier Heating & Cooling
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
When I turn on my netbook, the screen stays black. Nothing appears.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway LT2030u Netbook
My dynamix treadmill the red power light comes on but the circiut board not powering up
I suggest checking your power plug then check or reset the circuit breaker or fuse holder on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board, if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Exercise & Fitness
WILL NOT START, HAS POWER.
Does the motor run? Heater heat? Check the power connections inside the dryer where the power cord is terminated. If you have a voltmeter, measure across the two outside wires (220 volts AC) then either outside wire to the center wire ground (110 Volts AC). If this checks ok, then the problem may be in the controller unit.
Aug 15, 2009 | Dryers
Ac compressor won't kick on
Just had the same issue and posted. Just found the solution is the control module in the dash. Went to the junk yard since new is expensive on these units. Plugged new unit in, was able to charge a/c now blows cold as ice.
Mar 08, 2009 | 1991 Chevrolet Silverado 2500
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Yamaha dsp-/e300 wont switch on
check your speaker wire and speaker for short circuit.
Jan 17, 2008 | Yamaha DSPE390 Amplifier
Frigidaire FAA065M7A Air Conditioner Logo
529 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
