Question about GE Tritonr XL GSD6260JCC Dishwasher
Washer leaves resadue on dishesfrank
Have cleaned washer with cleaner,changed soap,ran it with no soap at all,still has same problem. what do you advise. thank you
  • GE Master
  • 43,501 Answers
How can I prevent mildew/slime in the agitators of LG a front-load washer?
Use powdered soap, not liquid and do not use fabric softener. Use plain white vinegar in softener dispenser in place of softener. Liquid soap and softener both leave residue, which buildsup to a film which molds/mildews. The vinegar is slightly acidic which kills mold/mildew and also helps release soap film from your clothes leaving them cleaner.
Jul 20, 2017 | LG Washing Machines
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Can't get rid of the soap...
One buy dishwasher cleaner or run bleach in it. But the reason why is because of hard water the hard water makes the soap stick to everything. And you might be using tomuch soap only use the main side not both and make sure you us jet dry. But the beat thing you can do buy water sofiner and then you can us even less soap and it will clean better and save the life of your dishwasher. Look at the film you can see, now think about the film you can't it's pritty sick
Apr 29, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
The rinse cycle on my washer leaves soap and the spin cycle leaves water. I've decreased the amount of soap and ran through another spin cycle with no change. I ran the spin cycle while watching it and at...
Good day,
There is blockage between the outlet of the tub on the machine to the end of the hose.
First, if you have the outlet hose that is fitted into a standpipe, that could well be the problem.
In other words, there is nothing wrong with the washer, it is plumbing problem in the vertical drain pipe. Happens often.
Shut the water to the machine off, remove one of the hoses, and stick it into the stand pipe. Turn the water on. If it backs up, that is your problem.
If not, then the machine is at fault. A hose runs from the bottom outlet of the tub to the pump. Then from the pump to the outlet hose.
You'll need to remove the hoses, and pump to inspect them. It's even a possibility the pump's impeller is slipping, and lastly, check closely where the hose was removed from the bottom of the tube. Could be the classic "sock" problem.
You did not give the model. Get that information, and then type into google....................
"How to change a water pump on a ( your info) washer".
You'll get the hits you need to see how to access the pump and related accessories.
Dec 09, 2009 | Kenmore Washing Machines
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
I HAVE FRONT LOAD LG WASHER - CLOTHES ARE SMELLING -- CAN WE USE 2 CUPS CLR & RUN WASHER WITH NO CLOTHES TO CLEAN WASHER DRUM & DRAIN HOSES. IS THERE A BETTER SOLUTION TO PREVENT THIS PROBLEM
Comments: Jul 21, 2009- Well, with that model I'd guess you are in the UK, and I don't have parts breakdown or service info on those models, but I'd run the front load washer cleaner through it. Not sure which ones are available over there. You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Jul 29, 2009 | Washing Machines
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Dishwasher
go and stop at SEARS and buy some dish washer magic ,, use about 2-3 times should resolve problem... also for washer ,, they sell washer magic to clean and remove smells and mildue ,,,,,
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
GE Tritonr XL GSD6260JCC Dishwasher Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
