Question about Hifonics Brutus BX12D4 Car Subwoofer
I have a alpine M500 amplifier running a hifonics brutus subwoofer and i think it is blown. I don't understand how this could happen as the amp is only pushing 500 rms and the sub takes 600 rms. I got no smoke or smell. The sub is dvc 4 ohm in parallel. So total impedance at the amp should be 2 ohm. And the amp is 2 ohm stable. Any help would be great.
  • 416 Answers
Hmmm, let me see here. Did you mean to say you have TWO subs connected to this amp? A single sub can only be wired in series with the amp. Even if you have a capacitor wires in parallel, the capacitor is not a load, but a souce equivilant, and therefore can be merged with the amp as a single source when put on paper.
When they say a sub or amp is so many watts rms, that means that the device can function safely, without worry of failure. THERE IS NO LEGAL METHOD FOR DETERMINING THIS NUMBER AND NO REGULATIONS ON VARIANCES. Having said that, if an amp is 500w rms, it could very well push double that for long enough to blow your speaker. It all depends on how much power went through that speaker. So since you have a 4 ohm speaker, not two, and it would actually act like a two ohm speaker if you put another one in parallel because 4||4=2ohms equivilant. never never never, turn the bass all the way up if your gonna beat loud. Low frequencies draw lots of power and can damage your system.
you can tell if your speaker is blown by turning the volume to a medium listening level and placing your hand on the cone. you will hear a crackling sound if it is blown
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on Jun 05, 2010
Testimonial: "You basically told me stuff I already know. The sub is just kind of old. The tinsel lead just blew. I re-soldered and its all good now. "
I have 2 12 inch jl audio w7's with a kicker crossover and a powerbass equalizer 5 bands. i wanted to know if add a hifonics brutus 2100 d class amp to my subs at 1 ohm would it over power my subs. please...
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Dec 22, 2010 | Hifonics Car Audio & Video
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
Have 2 blown square hifonics 12inch speakers. Was playing goos and then just stopped. Took to radio shop and they said I have 2 blown sub-woofers. How can i get them fixed.
They probably will have to be reconed. Slight chance the flex leads have broken in which they MIGHT be repairable. If this occurred during playing very loud, you probably burned up the voice coils.
Have them reconed and then use an amplifier that maxes out at MUCH less power to drive them. Also fuse the speakers to protect them.
Dec 04, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Amp light on , but subwoofers stop working after 5 seconds
check sloder conection in amp. if your amp is in trunk it copuld have over heayed and mealted the metal.
Jul 12, 2009 | Alpine MRP-M500 Car Audio Amplifier
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BXi 1208d Amplifier
Possibly you need to return the amp and get a new one cause that could mean an internal problem and its deffective, you could try replacing the fuses or try changing the ground wire, this problem is very unusual
Sep 13, 2008 | Hifonics Car Audio & Video
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BX12D4 Car Subwoofer Logo
149 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
