Question about Vizio Televison & Video
Vizio 37" LCD has a black picture with vertical streaming lines that are white.
  • Vizio Master
  • 3,866 Answers
This is a negative sign when the tuner/decoder goes bad, you will have these lines. I would take it to a tv shop and have them eval it because this issue is within the TV and not user serviceable to tell you the truth. So my diagnosis would be the decoder /tuner and again this is without looking at it so keep that in mind, I thank you for giving me the opportunity to assit you but you going to need further hands in the cookie jar then a support session here,=. With vizio as a whole at the time if it where me I would cut my losses and grab a new sam-sung to be honest. This name brand TV is common with these decoder/tuner failures so keep that in mind.
Posted on Jun 05, 2010
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
I have a vertical line that runs through the picture on a Vizio VW37L HDTV30A. Can it be fixed?
Possibly, could be a faulty LCD/T-con ribbon cable connection or a faulty LCD panel tab connection. Unless you are experienced in electronics repair, I would recommend you get a qualified service professional to look it over. But again there is a chance it can be repaired
Feb 26, 2013 | Vizio VW37L 37 in. LCD HDTV
I have color vertical lines instead of a picture on the screen
color vertical lines means the lcd PANEL is gone bad. it is a costly part which can cost more then 70% of the total cost. you need to replace it.
Sep 26, 2011 | Vizio E370VL 37 in. LCD HDTV
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
